I can't solve 2 blanking troubleshooting in outdoor P C board. Please explain
3 Suggested Answers
  • 462 Answers
SOURCE: bryant a/c heat pump "model540bj024"
I have to start with the wire diagram. Find the circut board. Look for any connections marked to the thermostat and follow to what they go to. See what other controls it has pressure sw, tenp sw, ,,, then decide how its suppose to work.
This may not help you but it is a direct answer to your request. If you need more infor I need more info and spicific  on what you want to check.
Posted on Mar 03, 2009
  • 358 Answers
SOURCE: bryant a/c heat pump "model 540bj024"
Check if you have 24volt out of the board if not replace it.
Posted on Apr 03, 2009
We have enjoyed a Rheem Thermostat and a Paloma Eco Sense tankless gas water heater #RTG-74XN-2 for 2 and 1/2 years, but now there are error codes flashing and resetting the thermostat doesn't hold. ...
Before calling service technician, open following links for Rheem troubleshooting resources, including generic error codes and contact information for Rheem and recent manuals:
Error codes are start place for troubleshoot, and multiple error codes can indicate bad PC board.
Same error code on one machine can be different cause and solution than another machine.
Error 76 is usually communication problem with remote control.
Disconnect wires from machine, and clean terminals is a start point.
Wire between machine and remote might be bad, or remote control is bad, or PC board or wiring connections are bad.
The problem might be solved by having technician catch the machine up on yearly maintenance.
Manual for same-similar product shows maintenance and troubleshooting and a few error codes, but not 76:
For the most part, the manual recommends calling service technician instead of offering DIY details.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
White screen on my zen
Please, watch this video which explains how to solve the white screen for your mp3 player:
1. Fully charge the unit.
2. Get a song to play.
3. Lock the device by moving the Hold/Power switch up.
4. Wait for the screen to blank to black, and also wait an ADDITIONAL 25-seconds after the screen blanks.
5. While holding the Play/Pause button down, move the Hold/Power switch out of the lock-mode, and all the way down (like you're turning it off).
6. Release the Play/Pause button.
Feb 03, 2011 | Creative Labs Audio Players & Recorders
Circuit breakers tripped, had to replace fuses in the outdoor disconnect panel, after replaced fuses and turned on the breakers, I get F1 Error in air handler display which indicates a communication error...
Typically power going into the board but not coming out points to a bad board. Communication errors usually stop at the board, meaning components are ok but board is not. Cycle the power to both units, verify high and low voltage to the board.
Nov 21, 2017 | Amcor Aire AMS241HX Split System Air...
When tv gets powered on the screen flickers for about one second then goes blank
The tv 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like, to buy those 2 refurbishes long LCD inverter boards for the replacement.
Aug 05, 2010 | Toshiba 40G300U TV
I have a Kenmore dishwasher 66517033400 that has a flashing green clean light. The light is flashing 7 times per cycle.
This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 09, 2009 | Dishwashers
Mod# A-SMH18SA SER# 2791206189 Heat controller mini-split. Cust says lights flashing on board- he resets it, yet it resumes to just flashing at the board. Nothing runs. Long drive out there- any ideas. Was...
First of all, Heat Controller does not mount any schematics on their systems panels at all and supply no information for the service tech to code the light on the outdoor board. This is unbelievable.
Anyway- I found that the electrician had re-arranged breakers in the panel supplying the building and had connected the outdoor heat pump to 120v instead of 240v. He had interpenetrated the connection at the unit that has marked 2(N) as being a neutral connection. I explained that on 120v systems, that is neutral, but on a 240v system, it's L2. The outdoor board was flashing 5 times after the power was turned on for 3 minutes. Voltage at "S" was 38.4v, with this condition and the indoor units lights (all) were flashing every second and beeping as well.
It's running fine now that we are connected to the proper voltage.
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
