I can't solve 2 blanking falut in outdoor PC board
My usb ca-101 cannot detect in my pc
1:This falut Is Your data Cable.
2:This falut is Your Mobile Deta Cable port.
Aug 08, 2012 | Samsung GT S3850 Corby II
Memory card not working
1:This Falut Is Your Mobile Memory Card:
2:This Falut is Mobile Phone.
Jul 31, 2012 | Nokia 6120 classic Cellular Phone
WIFI NOT RESPONDING
This Falut IS Board Please Change The Board .So Your Problem Will Solved.
Jul 31, 2012 | Computers & Internet
Help please...my Dell desktop Inspiron 518 won't turn on at all.
First Option:Please Take a New Window .
Secon Option:This Falut is Hard.
Last Option:This Falut is Your Board The Board Is Shatig.
Jul 30, 2012 | Dell Computers & Internet
UNMOUNTABLE_BOOT_VOLUME
First Option: Please Update it Sound Software
Second Option:please Take A new Window and install Drivers
Third Option: This Falut Is Cd Room
Fourth Option:This Falut Is Hard.
Jul 30, 2012 | Gateway Computers & Internet
How do i insert a memory card into my INQ clould touchphone?
1:Its Falut Your Memory Card please Change Your Memory Card.
2:It Falut Your Tuch Phone Please Change The Phone/
Jul 29, 2012 | Cell Phones
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
Mitshubishi split muh-18nvand inside msh-18nv
-Start the unit.
-Press EMERGENCY OPERATION switch.3-minute time delay works.Test run operation operates for 30 minutes.
-Check voltage to terminal block of outdoor unit.Is there 12V DC between 2-1?
-If voltage is presenet check the wiring, compressor contactor outdoor fan motor and compressor.
-If no voltage check voltage to terminal block of indoor unit.Is there 12V DC between 2-1?
-If if voltage is present re-connect the continuity of indoor and outdoor unit connection.
-If no voltage replace the indoor electronic control P.C.
board.
-But also check the coil thermistor sensor and room air thermistor if this two is out of range it can cause the tripping of out door unit. It has the resistance of 8 to 10 k ohms at 25 deg c temp.
Jan 04, 2008 | Heating & Cooling
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
