Question about Cell Phones
I am connected to the Care Alert system on my home phone .Do I have to have anything changed.
Answering machine will not work
Power off the device and plug it back in. If that doesn't help, check the manual to see if there is a setting you can change. Next try the manufacturer's website for a FAQ that addresses your situation. Finally request a replacement from the manufacturer, assuming it is still in warranty.
Dec 18, 2011 | Panasonic Lands Phones
Tip
How to Operate a Home Security System Without a Contract
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
  • Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
  • Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
  • Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
  • Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
  • Tips & Warnings
    • Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
    • If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
http://www.securityalarmchina.com/
on Mar 29, 2016 | Home Security
Tip
1200 ,1112 ,1110i ,1200 ,1208 ,1209 ,1600 ,1202 common problem
do you know that you can fix the common problem of nokia 1110 ,1110i ,1112 ,1600 ,1202 ,1200 and 1208 in your home and didnt lost your time and money by going to a cellphone repair shop or nokia care center...one of the caused of the said problem is the corrupted software of your phone..<br /> <br /> some of the problem that encountered by nokia phone 1110 ,1110i ,1112 <br /> ,1208 ,1200,1209 ,1202 etc .is not sending sms even you have signal and turn off when you go to tone settings if you want to change your message alert or call alert tone...<br />it is software problem but you can do it by youself by doing this...<br />1.MENU<br />2.SETTING<br />3.RESTORE FACTORY SETTING<br />4.ENTER LOCKED CODE (if not change it is 12345)<br />5.WAIT UNTIL PHONE IS REBOOT...<br /> <br /> after rebooting the phone ,test it and now you can used it in good working condition..but before you do the above action ,make sure that you save all the numbers in your sim directory becaused it will all deleted ..to save the contacts from phone to sim just do this..<br /> go to menu&gt;contacts&gt;copy &gt;select ,from phone to sim card &gt;all &gt;keep original and wait until its done ...<br /> i hope it will help you ,thanks for trusting fixya...<br />
on Feb 12, 2011 | Cell Phones
I cannot connect to google. I used to have google email connected and keep getting a message saying cannot connect.
hi,firstly see that if you have internet conection or not ,if you have it then see for you internet setings you can call to customer care for recieving them
Jul 04, 2011 | Samsung Galaxy S GTI9000 Smartphone
When i select ring tone my nokia 1650 mobile get switched off
hi,
i have a solution on that kind of trouble in my Tips here.............http://www.fixya.com/TipsAndTricks/posttipandtrick.aspx?thid=8247630
i open it for you:
do you know that you can fix the common problem of nokia 1650 ,1110 ,1110i ,1112 ,1600 ,1202 ,1200 and 1208 in your home and didnt lost your time and money by going to a cellphone repair shop or nokia care center...one of the caused of the said problem is the corrupted software of your phone..
1.MENU
2.SETTING
go to menu>contacts>copy >select ,from phone to sim card >all >keep original and wait until its done ...
Apr 26, 2011 | Nokia 1650 Cell Phone
Tip
Do you know that you can fix nokia phone problem of not sending sms ?
1.MENU
2.SETTING
on Jun 14, 2010 | Cell Phones
Tip
Eaton Home Heartbeat HOMEkey Description
The HomeKey (included in all HOMEheartbeat Starter Packs) is used to program your sensors and change your system's setttings. Attach it to your keychain or place it in your purse and take it with you. Then, when you (and your HomeKey) leave the range of your Base Station (range of approx. 150 feet in open air), your Home Heartbeat system knows you're away from home and that it will "alert" you with text messages and emails about changes in the status of your home!*
Important Note: *When setting up your system and sensors be sure to take time to setup whether you want to be alerted 1) only on your HomeKey (at home), 2) to email/cell phone when you're away, 3) to your email/cell phone always.
View the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat HomeKey
I have samsung e840 it have no vibrate no alert incoming call
Hi, did you set the vibrate alert on?.
If you did set it it will give you a vibrating alert.But if not that means you will have to go through where the ringing to setting alert and set the vibrate alert on.
After setting it and no vibration yet,that mean you will have to replace the vibration inside the phone.
Would advice if no experience with phones, contact an expert technician around you.
Take care.
Jun 15, 2010 | Cell Phones
When on silent, the phone still makes alert noises
Go into the main menu
Sound settings or Alert Settings
There will be an option for alerts (text messages) you can then change it.
Post back if you need further help. Thank you for choosing Fixya!
Mar 30, 2009 | LG enV VX9900 Cellular Phone
LG VX9400
Just turn the phone on vibrate.
May 18, 2008 | LG VX9400 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
