Question about Casio Televison & Video
Casio FV600 projection lcd tv power supply psb emage
3 Suggested Answers
Mr_Wizardtex
  • 205 Answers
SOURCE: casio fv600 projector
Use the video input, with the stereo audio and you will be fine. good luck
Posted on Jul 07, 2009
No power to the tv
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Dec 15, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
I received a hand me down philips 55" rear
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Kaufman605
Dec 13, 2010 | Philips 55PW9363 55" Rear Projection...
50hm66 Lamp LED flashing 3 times and stop then Lamp LED flashing, No power, Got a new lamp and same problem. Can anybody help me?
Sounds like you may have some faulty capacitors. Its a pretty common problem.
Here is the likely problem.
The Power Supply Board. I had a similar problem with my Phillips 42 in. Lcd TV. One day it just started turning itself off. Then it wouldn't turn on at all. I opened it up (warranty was expired of course)
and found several bad(bulged or leaking) capacitors on my PSB. Many major electronic manufacturers were sold capacitors that were highly rated but lacked preservative that caused them to fail after 2-5 years instead of 10-20. It wouldn't surprise me if your tv has some too.
Solutions
1. Take it in and have it repaired.
2. Check the PSB for faulty caps then buy a new PSB and install it.
3. Remove PSB, Remove and replace capacitors. This option will require some soldering skills.
Hope this helps. Good Luck
Dec 09, 2010 | Toshiba 50HM66 52" Television
TURN TV ON IT TURNS OFF I CAN HEAR THE RELAY
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Mitsubishi WS-48311 48" Rear Projection...
It shut off in 2 seconds of turning the tv on
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors. This may be your problem
Solutions?
Hope this helps
Dec 09, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I have a sony LCD projection TV Model # KF-50XBR800 and when I go and turn it on my standby button flashes red and then picture comes on for about 10 seconds then it shuts itself off. Can you tell me what...
Solutions?
Hope this helps
Aug 28, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Tv turned off by itself now TV button goes on but immediately turns off
Solutions?
Hope this helps
Aug 24, 2010 | RCA HD52W59 HDTV Projection Television
Casio fv600 projector
Jul 07, 2009 | Televison & Video
KDF46E2000
Solutions?
Hope this helps
Aug 12, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
22 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
