Question about Garden
What is correct Spark Plug Gap for Part No. RJ19LMC in a Masport Mower.
4x4papa
  • 14 Answers
SOURCE: Need spark plug gap for Viking MT830 ride on mower
Briggs & Stratton suggests 30 thousands of an inch for this engine.
Posted on Nov 22, 2008
  • 3 Answers
SOURCE: spark plug gap keeps closing on 2 stroke engine
it could be the spark plugs are to long and the piston is hitting the glug
Posted on Mar 22, 2009
  • 179 Answers
SOURCE: what is the correct spark plug gap
.35 to .40 should be fine also the parts store or a dealer can help
Posted on Jun 02, 2009
centralvalle
  • 386 Answers
SOURCE: what is the spark plug gap for a 6.5 craftsman
.025 "
Posted on Aug 11, 2009
  • 3567 Answers
SOURCE: SPARK PLUG GAP FOR A 3cyl.suzuki,660cc,12valve engine
From a factory service manual >
Could you take a moment and rate my answer? Thanks!
Posted on Sep 28, 2009
What size spark plug wrench is needed for lawn mower - model # 917.370441?
13/16 for the Champion RJ19LMC, Briggs & Stratton 591868
May 28, 2015 | Garden
What plug type goes in this engine
Since you did not specify the engine type, here is a site to find the correct plug and gap: http://www.briggsandstratton.com/us/en/support/faqs/identifying-the-correct-spark-plug-and-gap
Apr 19, 2015 | Ferris NEW 44 IS500 Series Zero Turn Lawn...
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What is the gap on a spark plug on a 18.5hp b/s engine rideing lawn mower
There are so many engines manufactured by Briggs and Stratton there is not enough information to answer your question directly. Suggest you check : www.briggsandstratton.com/...the-correct-spark-plug-and-gap this site with additional information about your engine should get you your answer.
Jul 28, 2014 | Cub Cadet Street Sign- tractor lawn riding...
How to replace ignition coil
you need a valve job the hotter the motor the more unseated the valves
Jul 01, 2014 | Briggs & Stratton Briggs Stratton...
What would cause no spark? the mower is a masport 8/02 two stroke. Will not start and I have changed spark plug and cleaned every thing but still nothing.
Your spark plug wire may be damaged, or your magneto may be too weak to generate a spark. You also have a kill switch wired to your magneto, and a condensor. I would start by cleaning the contacts of the magneto and then check the gap between the magneto and the flywheel. The gap between the flywheel and magneto should be .010". I would start by checking the kill switch wire for damage. If any damage is suspected, replace the kill switch. Next, I would have the magneto tested or replaced. Also, check all your ground wires for damage, or loose contacts.
When you are checking for a spark, you should have the spark plug installed in the spark plug wire as normal, but not installed in the engine. The spark plug base should be grounded to the engine while trying to start and checking for a spark. If there is a weak spark, this is probably due to a worn magneto.
May 24, 2011 | Briggs & Stratton Garden
My masport genius xrs will not start seems to be electrical, cannot see a spark with plug out of engine and connected.
hi if the xrs engine is briggs and stratton
try new plug 1st , then pull the kill wire from the stop switch and retest for spark
if still no spark take top starter cover assy off the mower and pull the kill wire off at the armature
temporarily fit the starter cover and retest for spark - if still no spark the faulty armature indicated
replace the armature - and set the air gap between armature and flywheel ( with magnets under it )to 0.010" and tighten the bolt - refit kill wire to armature and stop switch and refit starter cover assy and plug - should all be good
NOTE to obatain correct armature for engine make a note of numbers off the starter cover
eg 12f802-01215-e1 give the numbers off your starter cover to your local smal engine shop he will be able to get new armature for you .
cheers hope it helps
Jan 29, 2011 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
