I don't have a remote but my tv has no media device on it what should I do to fix this problem
How do i get remote clicker c-01v.2 to work with 40ru52r toshiba tv
the manual for the remote can be found here.
http://media.firebox.com/pdfs/clicker_web.pdf
this remote uses codes or learning function if you have the original remote for the device you would like to control.
Learn function is good because you can have one device button control multiple devices with different button assignment,
Aug 15, 2012 | Toshiba 47ZV650U TV
How do i reprogram my tv remote
Setup codes for RCA tv with this remote control are: 0047, 1047, 1147, 1247, 1347,
1447, 1547
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
Press and hold SET until the LED (red light) blinks twice,
then release SET.
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
Jun 13, 2012 | One For All URC-4021 Remote Control
Samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Jun 01, 2012 | Samsung Televison & Video
Remote on off has very limited dstance
Possible bad IR receiver in TV or IR receiver is not located properly in TV.
Dec 30, 2011 | Vizio SV370XVT TV
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
The philips universal remote codes for my apex tv don't wok. Since I put new batteries in none of the codes for apex tv work
Hello
Philips universal remote control cannot be synchronised with Apex Digital TV. There is no code for Apex with it. There are very rare remote controls which have codes with Apex Digital. Comcast On Demand Custom DVR 3-Device Universal Remote Control is one amoung them. Codes for Apex Digital Tv; with this remote are:
0748, 0765, 0767
Buy this one. It can be sychronised with most of the present devices. OK.
May 31, 2011 | Apex Digital GT2015 20" TV
The remote will not do anything for the tv and I also tried a universal remote and that did not work also
Remotes devices are heavily depended on it CPU chip for everything,it probally already dead.Tries clean the battery compartment like - + connections and replace it with new battery.Tv remote still don't work.Try website like Remotes.com to buy a new tv original remote.
Apr 18, 2011 | Panasonic EUR501455 Remote Control
I have the Samsung le40c580j1k and i want to connect to the internet. an ive set up my connection and thats fine, i just dont have the internet button on my remote, is there any other way of accesing the...
Hi
I have this tv, It is not a internet@TV model it only alows to stream media (Video, Photos & Music) using dlna enable devices (such as the samsung galaxy s) and windows media center.
Mar 03, 2011 | Samsung TV Remote Control
Toshiba Remote control conflicts with another device
I do not know of any possible address changes that can be made but the easiest solution is to put a piece of opaque tape over the IR eye on the device you use the least, the problem being that you can no longer remotely control that device.
The next easiest is to move the secondary device out of the line of sight and then just aim the remotes at different locations.
Feb 27, 2009 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
