Question about Samsung Tablets & eReaders
Samsung galaxy tablet will not turn on - Samsung Tablets & eReaders
Geekman
  • 32281 Answers
SOURCE: My samsung galaxy tablet is
It appears your Galaxy is faulty and it will still be under warranty. I suggest you take it to the supplier to get it repaired or replaced under warranty.
If you try to repair it yourself, you will most likely void your warranty.
Posted on Jun 25, 2011
reyjoshua07
  • 1157 Answers
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 17, 2011
SOURCE: Samsung galaxy tablet is frozen
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
Posted on Mar 14, 2013
Shilon
  • 104 Answers
SOURCE: my samsung galaxy tablet is frozen
Press and hold the power button for ~10 seconds.
Posted on Mar 19, 2013
  • 82 Answers
SOURCE: Can I get instruction manual for samsung galaxy 4 tablet
The operating and problem manual is already installed on the tablet.
Posted on Mar 05, 2015
My tablet will not turn off. It keeps restarting but will not get past the iRola screen.
About 15,600,000 results (0.52 seconds) Search Results
    The tab is in an endless reboot loop. - Samsung Galaxy Tab ...
    https://www.ifixit.com/.../The+tab+is+in+an+endless+reboot+loop.
    iFixitMy samsung galaxy tab 2 7.0 is turning on and off continuously. ... The second iteration of Samsung Galaxy Tab tablet computers with a 7.0 inch screen. .... to lose all the data, but still it does not lose and keep restarting over and over again.
    it keeps switching itself off - Samsung Galaxy Tab 3 10.1 - iFixit
    https://www.ifixit.com/Answers/View/.../it+keeps+switching+itself+o...
    iFixitMy Samsung galaxy tab 3 charges badly and keeps turning off and not coming ....What you will need to do is take the tablet apart, (carefully) and secure the battery to..... It shuts itself off and I have noticed that upon restart the Wifi is turned off.
    How to fix any Samsung Phone/Tablet that keeps rebooting ...
    ? 3:03
    https://www.youtube.com/watch?v=A-0LgvM-WNs
    May 30, 2014 - Uploaded by lennonSystems
    How to fix any Samsung Phone/Tablet that keeps rebooting(Boot Loop). lennonSystems ... with the s3 it does not work. trow it in the trash can ... When my phone does this I just let it do its thing, after a while it would stop.
Feb 09, 2016 | Tablets & eReaders
Tablet wont turn on fully it freezes on the opening screen than just freezes there and wont turn on all the way what can i do to reset it
How to Fix a Frozen Samsung Galaxy Tablet [Solved] - Samsung ...
www.tomsguide.com/forum/id.../fix-frozen-samung-galaxy-tablet.html
2 days ago - 30 posts - ‎27 authors
I have a Samsung Galaxy Tablet that is completely frozen. ... If done correctly thescreen will turn black and automatically start the reboot process. ... Sure have, it won't turn off, swiping the front screen doesn't do anything. My Samsung tablet won't turn on! - Samsung - Android ...
Jan 17, 2016
My Samsung tablet will not turn on. - Samsung - Android ...
Dec 30, 2015
My RCA tablet won't turn on. What do I do? - Tablets ...
Dec 28, 2015
Help! My tablet won't turn on! what do I do?! - Asus ...
Apr 1, 2015
More results from www.tomsguide.com
Jan 21, 2016 | Tablets & eReaders
My tablet has safe mode in left corner,hOW DO YOU SHUT IT OFF?
Get an Android Tablet out of safe mode - Support Home Page
acer--uk.custhelp.com/app/.../get-an-android-tablet-out-of-safe-mode
How do I get my Android tablet out of safe mode? Use the ... Restart your device by holding the power button, then tap Power off. ... Did this answer help you?
Samsung Galaxy Tab 3: Turn Safe Mode On or Off
www.technipages.com/samsung-galaxy-tab-3-turn-safe-mode-on-or-off
Mar 15, 2014 - Use the Safe Mode feature on the Samsung Galaxy Tab 3 to start the Android OS with the system default software. ... When the Galaxy Tab 3 logo appears on the screen, press and hold the "Volume Up" button. ... Once the device has completely powered off, you can press the "Power ...
Galaxy Tab 4: Enable or Disable Safe Mode - Technipages
www.technipages.com/galaxy-tab-4-safe-mode
Mar 4, 2015 - A tutorial about how to turn Safe Mode off or on for the Samsung GalaxyTab 4 tablet.
Power the Device Up in Safe Mode - Samsung Galaxy Tab 2 ...
Jan 20, 2016 | Tablets & eReaders
How do I turn my Samsung galaxy 10.1 2014 edition tablet on
hi,
to turn your
Samsung galaxy 10.1 2014 edition tablet on you need to long press the power button which is at the top-right side of the tablet.Hope youo get your problem fixed. Thanx
Feb 11, 2015 | Samsung Galaxy Tab 101 Tablet...
My samsung galaxy ce 0168 screen is not working anymore after 2 minutes turned on
Check that the charging port pins are not bent or damaged or corroded use a small needle to clean each individual groove. Replace the charger, suggest Staples or Walmart for the source.
Dec 05, 2013 | Samsung Galaxy Tab Tablet PC
My Samsung galaxy 10.1 tablet will not charge. It keep flashing between an empty battery symbol to a flashing yellow battery symbol. going Off and On. I can not get it to turn on at all. Im pretty sure...
Hi my Samsung galaxy tablet is flashing icon on and off signal but not charging? I have tried turning off for 30seconds still dead what should I do?
Jul 30, 2013 | Samsung Galaxy Tab Tablet PC
My bluetooth on my samsung galaxy tablet wont turn on what do i do?
Do you have this problem before? You could turn off your Galaxy Tablet and turn on to try again.
If not then you'd better turn to Samsung tech support for help.
BTW, for Samsung Galaxy apps and video watching tips, you could turn to this blog: http://www.enolsoft.com/blog/?s=Samsung
Mar 22, 2013 | Tablets & eReaders
Tablet Samsung galaxy note How to use it
You may download a copy of the user manual here.
Jan 02, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
