Question about Food Processors
My food processor red light is on n tried to reset its not taking reaet what shud i do
The food processor stops working after use. I know there is a reset "hole" to make it start again. I can't see where it is and cannot find it in the manual. Please tell me where it is so I can...
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
Mar 27, 2011 | Cuisinart DFP-14BC Custom Food Processor
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
Flashing Red Light, will not turn on
Something needs to be reinstalled or reset. You may not want to turn it on right now. If that is a warning lamp. Is this the first time used?If so, unplug it and use the blade tool to manually rotate the motor in direction of normal rotation, rotate several times and hands and tool clear, plug it in. Good Luck_Ned_
Oct 30, 2009 | Food Processors
Cuisinart MP14 Will Not Turn On
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Cuisinart 11 cup processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Oct 13, 2007 | Cuisinart DLC-2011 PowerPrep Plus Food...
Power red llight is on, but the motor/blades won't go
Well, now I feel totally foolish. The handle on the bowl must be toward the front of the bowl, not the rear otherwise the operating post won't engage.
Aug 22, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
91 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
