My sound is diabled in accessibilty setting - Computers & Internet
How to diable the vibration on lg realm device?
Go to Settings --->Sound---->Then from there you should see options to turn the vibration off. Also check Sound profiles within the Sound menu
Feb 11, 2015 | LG Computers & Internet
Does the Microsoft LifeChat LX-2000 Headset work on the ps3
Yes, every head set is capable of receiving audio sounds only require the type of connectivty. For example, the headset may require pin connection so long as the device PS3 has audio outlet. Also, wireless headsets that communicate by wii fii would require powering on the wireless signal acquirer. Thereafter each device should ascertain signal transfer. usually, the PS3 would require powering on any wii fii accessibilty buttons to search an acquire wireless signals in this situation audio.
Jan 12, 2011 | Microsoft LIFECHAT LX-2000 RETAIL Headset
My screen display is oversized, how do I bring back to normal?
Sorry to read about your problem, I hope this helps you out.
goto settings then accessibilty the turn zoom off
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Apple iPhone 3G
My IPhone screen is magnified and it won't go back
If you tap it twice with three fingers it will zoom the screen out and if you do it again it will zoom it in .... after go to setting - General - accessibilty - zoom - turn off zoom
And It Will Never Happen Again
Jun 27, 2010 | Apple iPhone Smartphone
My sound card from computer is needed to be reinstall,the model is DFM-5621S HSFi.but my problem is it is'nt working
Can you check the device manager for sound setting as well for simple things are overlooked ,as in sound on Pc muted
or device diabled
Its easy to overlook these but usually a deivce installed on Xp or higher is almost instantly found then its up to you to go to device managee look for any setting that are stopping the deive form producing sound
then go to tech routine of removing reinstaling device drivers
SEE icon on task bar? open this and search setting /advanced for small issue settings
Jun 11, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Security has been diabled and the disc (set-up assistant) won't run. Need to set security back on.
The link below will take you through setting up the WEP on your router.
Let me know if you have any more problems or questions
May 21, 2010 | Belkin (F5D8231-4) Wireless Router...
I have an asus and my keboard it locked and i cant do anything with it just used the mouse how could i solve this problem
i think u have turned On the Accessibilty Options , yuo can close it from the control panel, or u have made a change from the Reg and Lang settings
Mar 15, 2010 | ASUS K50IJ-C1 Notebook
Sound card diabled
if you havent already, click start, run then type dxdiag and hit enter, and go to sound tab and see any reported errors, you may need to re install the driver. Also go into the bios f2 or del on boot up and check that the onboard sound is dissabled if you are using a pci sound card.
Aug 29, 2007 | Acer (54.AA806.001) Sound Card
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
