Question about kawasaki Garden
Where can i get the fuel tank for my hedge tremmer kawasaki tf22
    Top Expert:
  • kawasaki Master
  • 48,245 Answers
From the manufacturer spares , from any mower repair shop , from any kawasaki service agent
Posted on Apr 20, 2017
Why does my Hs 85 leak a lot right after I fill the tank?
fuel tank grommets and new fuel line should fix this issue.
make sure you get the OEM black fuel line. that's the stuff worth writing about.
Mar 19, 2015 | Stihl Hs 85 Hedge Trimmer 4137 1310a...
Why does my kawasaki hedge cutter start easily but stop when tilted at a certain angle
ummm, because the fuel pick up is not in the fuel. I bet it is ok when the tank is completely full right?
Sep 19, 2014 | Garden
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
In need of manual kawasaki hedge cutter
try the piratebay
its a utorrent thing. type in like kawasaki hedge cutter kht600d manual
Mar 13, 2012 | kawasaki Kht600d Gas Hedge Clipper Trimmer
We have a Kawasaki Hedge Trimmer TF22. I need to know the ratio of gasoline and oil to put in it
The oil ratio for the trimmer is 50 to 1.
Good luck and please rate 4 thumbs uf for the free answer
Jun 26, 2010 | kawasaki Garden
How to get new plastic fuel lines in fuel tank in my weed-eater hedge trimmer. the line is larger than the hole in the tank.
Oftentimes it helps to use scissors to trim back a portion of the new line. Start at the bottom and cut upwards at an angle. Put some lubricant (WD40, perhaps) on the line and slide the sharp point into the fuel tank. Using needle nose pliers, grab the line and pull it through. This will only work if you have the correct size line. If the new line you are using is too large, you probably can't pull it through.
Apr 20, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Kawasaki KHT600S hedge trimmer cranks but won't throttle up
need a carb kit and a new fuel filter in the gastank
Aug 10, 2009 | Garden
How to put new fuel hose into fuel tank on jonsered hedge trimmer The hole is smaller than hose
You will need to split the fuel line for about 2 jnches and push it through the hole then reach in the tank with needle nose pliers and pull it through.Then cut off fuel line square and install filter.
Mar 14, 2009 | Garden
Garden Logo
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
