Question about Mtd Garden
How do you attach the engagement cable opposite end from the deck (where it attaches to the handle) on an MTD yard man 42" riding mower?
3 Suggested Answers
  • 53 Answers
SOURCE: how do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Posted on Jul 08, 2009
jyackle5
  • 8197 Answers
SOURCE: MTD Yard Machine Model: 13RL771H029 46" deck Need
May I also get the serial # to help you with your problem
Posted on Jun 19, 2011
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Jun 08, 2010 | Mtd Garden
Where does the blade brake spring attach on an MTD 42 inch deck with manual PTO? One end connects to the blade brake pivot arm, but the manual is unclear as to where the anchor point is.
the other end goes on the pulley engagement swingarm so when you turn the blades on the spring pulls the blade brake away from the blade pulley so the blade can turn. hope this helps
Sep 13, 2009 | Mtd Garden
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
How do I change the blades on a mtd yard-man 42" riding mower
Jul 08, 2009 | Mtd Products Yard Machines 158CC Tiller
Yard Man 42'' Drive Belt Install
it is a mtd mower ,however you should be able to go to a tractor supply store with the decksize and the engine size and get the proper belt.AGAIN(TSC) store,OR TSC.COM HOPE THIS HELPS
Jun 08, 2009 | Mtd Garden
Garden Logo
27 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
