Question about The Computers & Internet
Wont connect to bluetooth
I did what the book said to do blue light flashes but will not connect
3 Suggested Answers
  • 125 Answers
SOURCE: how do I use bluetooth
First you have to "Pair" the bluetooth and the phone. Then make sure that the bluetooth function of the phone is turned on before you turn on the bluetooth.
Posted on Jul 13, 2008
micromatikal
  • 2777 Answers
SOURCE: HAICOM HI-408BT Bluetooth receiver will
That is a major malfunction of the unit. I believe this unit has a reset button on it, or can be reset from a menu. Try that, does it at least acquire satellites after that? If not there is something major going on.
Let me know, Tim
Posted on Oct 02, 2010
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
My em228 flashes blue red why?
It is NOT the battery. When you turned the bluetooth on, only hold the power button until the blue light flashes about 3 times. If blue tooth is enabled on your phone, this should allow the bluetooth to connect without having to search for any devices, that is, if you already have it in your settings.
The red and blue alternating lights are to setup the bluetooth and allow it to connect to your phone, THE FIRST TIME. Once the device is listed in the bluetooth settings on the phone, you can just connect, instead of searching for the device every time you need to turn it on.
Only hold the button until the bluetooth flashes BLUE, about 3 flashes........see if this works better for you.....
Another frustration, (sometimes) depends on what brand of phone you have. I know my EM227 connects differently between my DG Razr and my Samsung Eternity.
Let me know if this helps, and if not, let me know what phone you have, and I will tell you for sure, exactly how to turn on and connect, with no problems.
Good luck~~!
mstipps@yahoo.com
Nov 18, 2010 | Emerson EM227 Bluetooth Headset
Won't connect to trueblue bluetooth
my friend found her book with the instructions. You have to turn the phone on. Make sure the bluetooth is enabled. Then hold the power button on the bluetooth down until the red and blue lights flash back and forth. then try to discover it on the phone. it works!!!!!!!
May 11, 2009 | LG Vu CU920 Cellular Phone
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Explorer 220 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Lost instruction book
go on ur phone and go 2 bluetooth pairing. before u click pair, turn on ur headphones and hold the multi function( button w/ play button and phone symbols) button until flashes blue and red lights simultaneously. once flashing, enter and start bluetooth paring on ur phone. the code is 0000. enjoy using ur bluetooth.
Oct 18, 2008 | Insignia Bluetooth Wireless...
HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Jun 29, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Blue tooth
providing the mobiles that your trying to connect to are, bluetooth capable devices themselves. it,s the matter of getting the 2 devices to find or recognise each other ( connection Manager ) or device enabled settings.
If your mobile phone is Infa red then the 2 are incompatable. This can sometimes be determined via a little blue flashing light ( hence Bluetooth )
refer to your PDAs user and instruction guide for further assistance.
Mike @ compurepair.
Jan 08, 2008 | Acer N300 Pocket PC
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
