Question about Bosch Dryers
Bosch dryer does not start
Dryer started showing correct dry time and after it started time changed to much lower time and clothes were not dry. Now the panel is blank and dryer does not start.
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
  • 131 Answers
SOURCE: long drying time
Did you find what it was?
Posted on Mar 17, 2008
  • 18 Answers
SOURCE: LG DLE0332W Electric Dryer- The
Had the same problem, dryer got hot but didn't stay hot. sounds like you have a bad sensor and it sounds like it's out of warranty.
Posted on Jun 08, 2008
  • 19396 Answers
Check all fuses and circuit breakers , if they are fine, then the problem is with the control timer. You need to have the control timer replaced.
See also the following website: What is wrong with your Dryer?
You can get replacements here.
Posted on Oct 15, 2008
  • 3 Answers
SOURCE: LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
Posted on Mar 27, 2009
LG front load dryer jumps from 40 min to 19 min to 5 min in short time. Any suggestions?
Dryers can base their drying time two different ways. If you are using the "dryness" settings, when you first start the cycle, the timer will show a specific time. If the contents dry fairly fast, the moisture sensors in the dryer will reduce the remaining drying time. This may be what is causing your changes. If you want a specific time on the dryer, or the dryness settings aren't getting the clothes as dry as you'd like, opt for a "timed" dryer setting, where you choose the drying time. This bypasses the sensors.
Aug 02, 2016 | LG Washing Machines
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Dec 18, 2010 | Bosch Dryers
My Bosch Washer dryer does not spin to dry clothes
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Nov 06, 2010 | Bosch Washing Machines
Dryer unevenly drys clothes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
Jun 21, 2010 | Bosch Nexxt 500 Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Why does dryer stop when the clothing is still damp?
I`m assuming you have not received any error code from the dryer since you didn`t mention that, but would I be correct ?
Have you tried both timed dry and auto dry settings ? If this happening in both setting`s it will help narrow down what to look for.
Are the cloth`s typically spun out really well by the washer ( and is it a Bosch Nexxt as well ) before entering the dryer ?
I will watch for your response in this post and hopefully I`ll be able to help find an acceptable solution for you.
macmarkus :)
Apr 08, 2010 | Bosch Nexxt 500 Dryer
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
Jun 08, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
