Question about Dryers
Remote control quit working after power flicker, there are no chains or switches on the fan. part number on the remote is 99600
    Top Expert:
  • Dryers Master
  • 44,133 Answers
  • Disconnect power at the source, not at the fan
  • remove battery from remote and press all buttons to eliminate possibility of stuck button. Reinstall battery
  • Reconnect power and test operation
If conditions remain the same, the power dip may have affected the receiver
Posted on Apr 20, 2017
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
We just recently installed a harbor breeze ceiling fan w/light and remote. During a storm the lights just quit working. What can we do?
Power outages cause ceiling fans to suffer memory loss. The basic "cure" is to disconnect fan power at the source and, while waiting a few minutes, remove the remote battery and press all buttons to verify that none are stuck. Reinstall the battery and test operation. Other factors may affect restored operation such as using wall switches and pulling the chains. The simple brain in the fan canopy can't remember switch and/or pull chain settings at the instant of power loss.
Jul 24, 2016 | Dryers
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
Hunter fan remote control 99600 button cover falling off
I don't know that remote # & there's nothing anybody on here can do to fix it. Call Hunter parts at 1-888-830-1326 with model # of fan.
Jul 06, 2015 | Hunter Dryers
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay 52-ANT
If you have a ceiling fan, they often suffer remote operation failure as a result of a power interruption. Try disconnecting the power source. Leave the local switches and chains alone. After a brief pause, apply source power again and try remote operation
Jun 28, 2013 | Hampton Bay Dryers
Hunter fan remote control 99600 not working
This must be a common problem, since I Googled the part number and it popped up before I completed the number. I am going to have to order a new remote, since I don't have a solder pen. Wish me luck.
Jun 22, 2012 | Hunter Dryers
Minka aire concpet 1 ceiling fan issue
Ceiling fans have tiny "brains" that get fuddled when one tries to combine remote control and wall switches/pull chains. If you want to be able to use remote control, redo the installation omitting the other switches.
May 30, 2017 | Minka (F517ORB) Ceiling Fan
Flickering lights
make sure you have the remotes/receivers set to different jumpers. I installed 2 fans and had the same problem, just had to change the jumpers on one of the fans and the corresponding remote
Jul 19, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Dryers Logo
87 people viewed this question
Top Dryers Experts
