Question about Mitsubishi Televison & Video
My mitsubishi wd-52628 is having distorted colors, have any clues?
  • 5 Answers
SOURCE: mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Posted on Jun 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Posted on Mar 15, 2009
ladywinn
  • 5138 Answers
SOURCE: Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Posted on Aug 19, 2009
  • 556 Answers
SOURCE: My Mitsubishi wd-52628 TV does not respond to any
Try to reinitialize the set , with the remote press menu 1 2 3 enter.
Posted on Nov 01, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
Jan 16, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Colors are off (NO YELLOW. BLUE) has a Green Hue to picture
there may be the possiblity of loose dvi cable between chasis and optical enngine. this is a cable much like a montor cable. it has two screws that tighten it down. reseting this sometime help
Dec 19, 2008 | Mitsubishi WD-52528 52" Television
Mitsubishi wd-52628 flashing green timer light
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Color problems
Your color wheel is bad. Thats the only thig that controls color on the DLP projections. You will need to replace it But I would check the connections on it first to make sure the connections are secure. Let me know if you require more assistance.
Feb 26, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
