Question about Home
Can a hotel charge me for a blocked toilet
We didn't notice anything wrong. Toilet in perfect working condition
    Top Expert:
  • Home Master
  • 49,960 Answers
It would be bad for business if it did as you could splash it all across media right or wrong
Stand up against the charge and make them prove that it was your fault or a lack of maintenance by the hospital
Posted on Apr 20, 2017
Toilet bowl will not drain when flushed
if your flapper is held open and the toilet rises to the rim and does not flush then you need a closet auger and clean out the toilet as it has debris restricting the flush
Mar 02, 2014 | Plumb Craft Perfect Flush Toilet Kit
HELP! How do I fix a toilet that will not flush? I suspect the wax seal has not sealed properly due to tile floor being added and raising the level of the toilet. Could this be the problem?
I would have used low power jet wash with pipe cleaning attachment when the toilet was off, I know karcher do a good 1 but there are cheaper alternatives. The last toilet I fitted had a large rubber type seal between the wate outflow pipe and the out pipe of the toilet that fitted over the base of the pipe. I have never seen a wax type seal as you describe, admittedly I have not changed many toilets, but I would have changed the seals when the tiolet was lifted. Hope this helps
Mar 04, 2017 | Home
Water is leaking slowing after filling up the tank and water supply is shut off. where is the leak?
In this toilet there is a flapper valve that blocks the hole for the water to transfer from the tank to thebowl. If you fill the tank and water is leaking into the bowl put your hand in the tank and apply alittle pressure to the flapper, the leak should stop. You can buy replacement parts for this toilet at Home depot or Lowes they carry universal lits that are perfect for this issue.
Jun 14, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
Toilet was working perfect this morning until I flushed it and then the water would not stop. I turned the water off completely
The Shut-off mechanism inside the toilet tank is staying open. Turn the water back on, Remove the tank lid and flush to see exactly what is going on. You should notice that the rubber piece of the mechanism does not go back down to cover the flush hole. That should be your problem. Spray some lubricant (WD-40) on the moving hinge at the top of it or replace the entire assembly.
Jan 14, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
Hi, we installed the toilet two days ago and it was working fine. It has just stopped refilling. I do not see anything wrong.
there is likely a sediment build up either in the fill valve of the toilet or possibly in the supply line. You can try shutting off the water to the toilet, disconnecting the supply line from the tank and running the water into a bucket to see if the toilet is getting a water supply. If so, then you may need to replace the fill valve. For future reference:
Any time you install a new toilet or remove and reinstall a toilet, it is a good idea to flush the water lines (as described above) before replacing the fixture. This can help to remove sediment from the water lines and the Shut off valve and prevent the sediment from building up (and eventually clogging) the fill valve.
Nov 24, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Our toilet bowl's water level drops to maybe an inch depth, Why?
it could possibly be cracked inside the bowl sometimes its not noticed only way to find out is to replace flapper if stlii loses water replace toilet bowl
Mar 11, 2010 | Home
What toilet is best.
American Standard Cadet
Apr 10, 2009 | American Standard Home
Spam filter test
My toilet is a hotel toilet. Would you like about 50 shampoo bottles and soaps? your friend, Steve
Nov 09, 2008 | Home
How to Improve Sanitary Conditions
You should use toilet seat paper covers. In addition to promoting sanitary conditions, the use of disposable toilet seat covers can also help your organization to save both time and money. When you consider the alternatives of toilet seats, it is easy to see how beneficial toilet seat covers can be. When visitors to your restrooms use the proper toilet seat covers, restrooms are more easily maintained.
Aug 27, 2008 | Kohler Flush Actuator K 9446 [ Bathroom,...
Home Logo
32 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
