Question about Welding Tools
GMC EASY MIG 101 WELDER MANUAL - Welding Tools
    New Friend:
  • 16 Answers
Https://www.adturtle.biz/LP_TA/index.cfm?T=437465
Posted on Apr 20, 2017
Hello,I am need of a user manual for chicago welder 131-2
Try Googling (Chicago)(131-2)(manual) without parens OR request the manual from Harbor Freight.
Apr 08, 2018 | Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Ive got a mig welder and somehow the wire got stuck in the lead and i cant get to it to pull it out .How do you get to the wire out if you cant see it ? Thanks Mike
Hi Mike:
The only way to take it out is by taking the gun's liner out and replace it with a new one. Liner will cost you around 15.00 bucks. If you are in the USA try the following site you can order it and they will ship it by UPS to your door.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1.
Check your owner's manual on how to replace it. It's an easy task.
Have a good weekend.
Sep 09, 2011 | Lincoln Electric Lincoln Easy MIG 180...
I have a mig 101 wire welder serial number B-37491-1986. Can I use flux core wire instead of the gas. The welder states .24 or .030 size wire. Are tips available for this welder ?
I have a mig welder that said it could use flux core wire.
Usually, .030 is what I use.
I am not sure if yours is this way, though.
I gave up on using the gas, because my canister was too small to make it practical.
I bought mine from Pace Member Warehouse which turned into a Sam's Club years later.
Good luck.
Jun 21, 2010 | Welding Tools
My 180 MigPak will not deliver argon to the torch. The tank is turned on. But won't let gas flow when the trigger is squeezes. Stick the torch in water no bubbles appear. What could be the problem. ...
Your gas hose or torch could be bad or plugged. Your gas solenoid on the welder itself could be bad. Disconnect the torch gas hose at the welder and see if you have gas coming out of the welder itself.
Jun 28, 2010 | Lincoln Electric Lincoln Easy MIG 180...
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
Jan 23, 2010 | Welding Tools
Welding Tools Logo
507 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
