Question about Olympus Photography
Olympus OM-4 stuck shutter
I have a olympus om-4 that every time I advance a frame and take a shot the shutter will stay up and I can't advance the frame. The shutter will only go back down if I push the B lock button and set the shutter speed to 60 or B.
    Brigadier General:
  • 3,006 Answers
This is very common on many OM SLRs and is caused by dirty shutter magnets. If you look on the web you can find details on how to do this yourself, but as the OM-4 is top of the line I'd highly recommend getting it done professionally as part of a CLA (clean lubricate adjust) service. Last time I had it done in the UK it cost about £80 and when I had it done to my OM-2SP in the USA last year it cost just under $100.
Posted on Jul 26, 2009
    Problem Solver:
  • 13 Answers
I see many OM-2S, 3 and 4 with jammed wind mechanisms. This is caused by "overwinding", Gears are now out of sync, shutter is trying to unwind, but gear position is not allowing it. Wind mech must be disassembled, degreased, rebuilt. OM is my specialty since 1977. www.zuiko.com. John
Posted on Oct 14, 2010
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
Aug 19, 2014 | Olympus Om Auto Extension Tube 7 For Om-1...
My film advance lever jammed in my olympus OM 2000 how to fix it??
Consult a tech - DO NOT try to force it, doing so will damage the gears and cause further damage.
If you don't have a local repair shop, I'd recommend KEH Camera located in Atlanta, GA.
Jun 19, 2011 | Olympus OM-2000 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
This is for you camera experts!!! I have an Olympus camera that belonged to my father. The only numbers on it are OM-1n. it is pre digital. I would like to find out more about this camera and possibly...
You can download a manual for the OM-1 from
http://butkus.org/chinon/olympus/olympus_om-1/olympus_om-1.htm
The OM-1MD is the same camera as the OM-1 with the added provision for taking a motor drive to advance the film automatically.
The OM-1n is the same as the OM-1MD with a redesigned film advance lever, a flash ready/sufficient flash LED in the viewfinder, and automatic X-sync regardless of the position of the FP/X switch, when it is used with a T-series flash unit mounted on Flash Shoe 4.
Aug 25, 2010 | Olympus Photography
I want to use my OM2000 Olympus lens for my video Canon XL1, do you know Olympus has built any lens adaptor to Canon XL? Reap
Olympus did not make adapter for OM lenses to be used on Canon XL1 but, if you are looking for the lens adapter, Novoflex XL-OM Lens Mount Adapter Olympus Lens to Canon XL-1, is the lens adapter that suppose to work.
B & H has this adapter for sale.
Jun 23, 2010 | Olympus OM-2000 35mm SLR Camera
I put in new batteries but the film will not advance and the shuter will not work?
Film advance on your model is entirely mechanical and is not affected by the batteries, but it does interlock with the shutter mechanism which is entirely battery dependent.
Unfortunately, OM4's are were notorious for having a main circuit board which corroded. There were a number of revisions to the board and the OM4-ti had a major revision which improved things greatly but didn't fix it entirely. If the board's faulty, your camera has become a display piece only as it cannot be fixed and spares are impossible to obtain. It doesn't help that OM4-ti's were made in far fewer numbers than regular OM4's and that the boards are not interchangeable between them.
It is still possible though that the fault is due to the camera just needing a thorough CLA service (Clean, Lubricate, Adjust) but expect to find that some mechanical parts may need to be replaced, especially if the film advance has been forced. If the shutter assembly is faulty, then once again you're into rocking-horse poo territory as it's unique to the OM4-ti. They can't be obtained new any more, but they can be taken from scrap OM4-ti's which suffered circuit board failure.
Note that due to the complexity of this model most repairs are not a DIY option. Repairs will not be cheap, but an OM4-ti which is advertised for sale with proof of recent professional repairs and servicing by an Olympus specialist is worth a lot of money so is often a worthwhile investment.
Apr 24, 2010 | Olympus OM-4TI 35mm SLR Camera
Shutter release and film and advance not working on Olympus OM-N1
for shuter ,the spring ,or mirror lock wornout,rebts in shuter may wornout,for film advance lever cheek for rewind buton on botm
Apr 15, 2009 | Photography
Olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
Apr 06, 2009 | Olympus FE-330 Digital Camera
Olympus OM-4 Shutter Release Button Stuck
  1. First ry to reset the Self Timer lever.
  2. Try to change the aperture.
  3. Try to unscrew the lens
  4. Open the film chamber slightly (just to loosen any lever that has got stuck)
One of these operations would dislodge any normal lever jam. If these fail to solve the problem, take it to a repair shop.
Jan 26, 2009 | Photography
Olympus om f manual
Hey _tj_,
The reason you’re not finding a download of your cameras manual is because the Olympus OM F is actually the Olympus OM 30, and was only called the F in limited markets. To get a download of your camera manual Google search "Olympus om 30 camera manual download" and the first link should bring up your camera's specs, and down at the bottom of the page there is a link that says OM manual. This link should bring up a PDF file of your camera's manual.
Sincerely,
Allan
Go Ahead. Use Us.
May 07, 2008 | Photography
Photography Logo
947 people viewed this question
Top Olympus Photography Experts
mbutkus
Level 1 Expert
Bart Pulverman
Are you an Olympus Photography Expert? Answer questions, earn points and help others
