Question about Sharp Office Equipment & Supplies
Where can I find a Printer Driver for this Sharp AR-BC320
SOURCE: I Want Printer driver for AR-5316
http://www.sharp.co.za/techweb/drivers/copierdrivers/gdidrivers/gdidrivers_5316-5320.htm
welcome to pattaya thailand
Posted on Apr 15, 2008
Benimur
  • 6966 Answers
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 17, 2008
SOURCE: driver sharp ar-5220
Driver Sharp AR-5220 Please.
Posted on Dec 05, 2008
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Posted on Jan 11, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
PLEASE HELP!!! Sharp AR-BC320 printer! We purchased this printer and do not have the installation cd that came with it :( Can anyone please please please help?!
If you manage to locate an Sharp AR-BC320 printer driver CD it may not have a Vista driver but it definitely would not have a Wndows 7 version and Sharp would not create one for this old printer.
I have found a lot of people are having problems with printer drivers for old printers with Windows Vista and Windows 7.
I suggest you purchase a new printer that support Vista and Windows 7.
May 09, 2012 | Sharp AR-BC320 All-In-One Led Printer
Hi
Download a PCL5e driver from here
This printer should work with any PCL5e compatible driver, you may not be able to address all of the trays etc, but you can overcome this by changing tray at print time on the printer control panel.
Regards
Plain Printed and Barcode Labels
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
AR BC320 H5-01 error Need to know how to clear it
# * C * in fast sequence. Then enter simulation 14 and press start button. Hit yes to confirm and then the copier will reboot.
Sep 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
How do i clear a F9-00 code for the sharp ar-bc320 copier?
Put the machine in test mode with the following key sequence:
P - * - C - *
then, 14-Start ... Execute ... Yes
CA to reboot the machine. For good measure, shut the power off, wait, and turn it on.
PS. - Get your copier on its' own outlet and share it with Nothing!!
Jun 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Copier Sharp AR BC320
i'd try consumer reports or Cnet.com for reviews, and that might let you know more about it..
got backup for that computer?
Feb 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
