Question about GE Refrigerators
Ge gsh22jfta fridge won't come run after being unplugged for 10 minutes. Lights are on in the fridge. Is there a reset
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
  • 25 Answers
SOURCE: I have a GE Microwave that stopped working after
If it is new take it back to dealer. If not diagnose with tech and get parts to repair if not too difficult from this website
Posted on Jun 21, 2010
  • 308 Answers
SOURCE: have model GSH22JFTA WW and there was a power outage. The inside lights are on but it is not cooling either side.
check breaker one contact might be burned up if the breaker is fine replace the receptacle with a 20amp grounded receptaclebv
Posted on Jul 25, 2012
spyder301975
  • 101 Answers
SOURCE: Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Posted on Aug 20, 2012
SOURCE: kenmore elite 10654606300 won't turn on
Do you have power at the outlet? If you do, your breaker trip as soon as you plug the unit in? If you have power to the unit and your breaker is not tripping, inspect the wires from the power cord to make sure rodents have not chewed the wires. If everything else looks good then you have a bad cntrl board PART NUMBER: 2252116
Posted on Mar 25, 2013
Power went out, and my g.e. refrigererator lights are on inside but the ice and water panel is off and fridge has not run sense
Unplug your refrigerator from the wall current. Wait 10 minutes and plug it back in.
The powere outage may have tripped an internal breaker. Usually, unplugging, waiting 10 minutes and plugging the fridge back in....will reset the internal electronics. Good Luck!
Mar 04, 2016 | Refrigerators
Beeping sound on ge refrigerator side by side
Sometimes you'll get that if the door isn't completely shut because something is stuck between the door and gasket. If you check that and it all looks good try unplugging the fridge for 10 minutes and then plugging back in. That usually resets the computer.
Mar 24, 2015 | GE Refrigerators
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
I have a GE GSH22JFTA WW that will not dispense water. Does dispense ice, crushed and cube. Panel is not locked. What part do I need? Thanks!
in the back of the fridge there is a module with the solonoid on it to open and close for the water, and it usually get damaged because of hard water, it is about 15.00
Aug 29, 2014 | Refrigerators
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
Have model GSH22JFTA WW and there was a power outage. The inside lights are on but it is not cooling either side.
Jul 25, 2012 | GE Refrigerators
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
