Televison & Video Logo
Gary Brasher Posted on Apr 20, 2017
I have a Mitsubishi WD-73640 with a flashing green light. How do I fix this.
  • Gary Brasher Apr 20, 2017
    Thanks for all the suggestions but none of these are in regard to my model of TV
5 Related Answers
Anonymous
  • 934 Answers
  • Posted on Nov 10, 2007
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Neal
  • 6 Answers
  • Posted on Feb 16, 2008
SOURCE: Mitsubishi WD-62628 power shuts off!
I have the same issue have not done the repair yet but here is a link to photos of the various boards and the problem caps:
http://www.fixya.com/support/t155026-
flickering_blue_picture
Anonymous
  • 103 Answers
  • Posted on Apr 26, 2008
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Anonymous
  • 5 Answers
  • Posted on Jun 17, 2008
SOURCE: mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Anonymous
  • 1689 Answers
  • Posted on Jul 27, 2008
SOURCE: mitsubishi wd 52825 tv It wont
it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature.
Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set.
by willtab
just a head's up, getting this repaied my cost a little big.
good luck
What is fast blinking green light on a Mitsubishi WD-73640
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
I HAVE MITSUBISHI WD-73640 AND ITS SHOW THE GEEN LIGHT BUT DOESN'T HAVE PICTURE OR SOUND
The first thing to replace is the lamp. Google your model number and "lamp" and you'll find several sites that sell them. It isn't difficult to replace yourself and isn't very expensive. Good luck.
Looking what i can do to fix. Have a Mitsubishi TV 3D DLP WD-73640, Replaced bulb, and still have the red LED flashing 6 times to the Yellow led flashing 1.
Check the lamp ballast too.
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
