Question about Refrigerators
I have a 5649215011 5 cu. ft. Where is the temperature control adjustment? How do I turn it off for defrosting?
I plugged it in after a long period of storage and it doesn't come on. There is no off/on switch or place to adjust the temperature.
  • Refrigerators Master
  • 20,292 Answers
You have three questions
You unplug it from the wall socket.
How do you control temperature?
Freezers are preset to -18'C or 0'F. Once set, they seldom need changing. The thermostat is hidden behind a grill or panel.
You put it into storage, took it out and it doesn't work?
Refrigeration units hate that, the compressor can seize up, gas can leak out, rats and mice can eat the electric insulation. You need it looked at or you need a new one.
Posted on Apr 20, 2017
How does to defoze refrigerator
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 02, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
No more
take to salvage yard they will pay u for it
May 13, 2014 | Whirlpool ED5DHEXWQ 25.3 cu. ft. Side by...
Talk to manager of ref. division
You may be disguested but with what? You need to write about what the problem is in order for me to help you.
Marty
Coed of
Hello Lori - First, make sure the freezer is plugged in and the plug is tightly pushed into electrical outlet. Confirm that the temperature control is not set in the OFF position. Set temperature controls to proper setting or set to the halfway point and adjust it up or down as needed. Also there is a possibility that the timer may be in defrosting mode, therefore it will not run. Allow the defrost cycle to complete and the unit should resume to normal operations. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Best, Chris.
Jul 16, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
Feb 13, 2013 | Kenmore 5 cu. ft. / 142 liter Upright...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    New upright kenmore freezer temp varies +/- 10 degrees
    Over what period of time did this variation occur?
    The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
    Oct 18, 2009 | Freezers
    Thermostat control
    Your system most likely has an automatic defrost system. The auto defrost system should actuate every 8 or 12 hours. Under normal conditions the water from the drain pan will evaporate between defrost periods. The defrost is controlled by a timer and NOT by the temperature controls.
    Jul 29, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
    Refrigerators Logo
    758 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
