Question about Bosch Dryers
REMOVE PANEL ON BOSCH DRYER
MODEL WTL5410UC DRYER NEED TO REMOVE THE FRONT PANEL TO REPLACE A BUTTON
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
mark_37388
  • 100 Answers
SOURCE: I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
Posted on Mar 30, 2009
vickygomar
  • 460 Answers
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
Posted on May 21, 2009
Jahn27
  • 1554 Answers
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Posted on Apr 21, 2010
paulcharmbur
  • 744 Answers
SOURCE: how do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Posted on Jul 19, 2013
Bosch 500 series new dryer has locked up. Key showing on panel, door opens, but you press every button and get the same beep.
Hi dear.
Regarding your information, I would say Child lock has been activated. I do not know what model or serial number of your dryer but you need to refer your machine's user manual or contact Bosch for deactivate child lock. I hope that helps. Thanks.
Jan 22, 2016 | Bosch Vision 500 Series Front-Load Washing...
We have a bosch front load stackable dryer that has coins stuck in the things that go around in the dryer, can we get them out?
You'll have to remove the top panel so you can loosen the baffles and get your coins out. Either that or take the back panel off and remove the drum altogether, which ever you find easier.
Jul 08, 2011 | Bosch Nexxt 500 Dryer
How do you remove the front panel where door is located
Welcome to FixYa.
I wouldn't do that...there is nothing or very little which can be serviced from the front. ( aside from the door itself and control panel of course ) all service on the WTMC Bosch is done from the back.
**Unplug the unit from the wall before attempting ANY service...safety first**
i.e.
Remove the top...
Then with the top off, remove the back panel...
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the front of the unit and components, drum rollers, motor, etc.
i.e.
Hope that helps you identify and access what it is you're after for your Bosch WTMC dryer, good luck.
Let me know how you make out or if you have further questions of course, I will help you move further in whatever manner I can.
Good luck.
Regards,
Macmarkus :)
Feb 23, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
I have a Bosch WTL5410 dryer, which has no heat going to the otherwise functioning tumbler. Do you know where I could purchase another heating element and where I can get instructions regarding the...
Open front panel, remove heat exchanger and clean.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the switch. This is your reset button. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
I have a Bosch next dryer that doesn't get hot???
there is a reset button on the hi limit thermal fuse located on the side of the heating elment can. this can be accessed by removing all the screws on the back apnel of the dryer( Make Sure the Dryer is Unpluged).once the back panel is removed there will be a black thermal fuse with two wires attache and a smalle red button between the wires bush this button in and this will reset the thermal fuse .if you have an ohm meteer check the continuity of the elment and verify that it is good.i hope this helps good luck with your dryer.let me know how things work
Jan 20, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
How do you remove front panel on a Bosch WFO285SGB
Aug 13, 2009 | Bosch Washing Machines
My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Feb 24, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
