Question about Kitchen Appliances - Others
Power cooker won't heat enough to brown. Shows e2 and E3. Won't work
SOURCE: My oster 3071 rice cooker ''E2'' error
it happened on my oster 3071 the error e2 just appear the only that i did was open it and I found out that the blue wire which is connected on the lid is cut so i just reconnect the wire and stick it together using souldering iron and presto it is good as new again
Posted on Jul 23, 2010
  • 15935 Answers
SOURCE: whirlpool cooker shows error code
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#@#$RWS
Posted on Oct 01, 2010
  • 34 Answers
SOURCE: Bravetti Slow Cooker won"t heat
Well if your o.k with soldering...or know a more than likely IS repairable. The manufacture puts in a thermal fuse that blows when the temparature gets to high. Radi0 shack stocks them...and might know of a local person to test / fix it.,HPIB:2010-05,HPIB:en&q=thermal+fuse&um=1&ie=UTF-8&sa=N&hl=en&tab=wf Here is what it looks like. AND you need to get the RIGHT tempature rated replacement. Hopefully a 10-20 dollar fix will save you 50-120 for a new one. Maybe you will get lucky and the fuse clips in like a vehicle fuse. Good luck Richard
Posted on Nov 15, 2010
  • 1902 Answers
SOURCE: My model Microwave KOT-1515 about
Hello & Welcome to FixYa
The problem is either with the a loose broken connection inside the unit or with the door switch that is bad and needs replacement. Please get back to me if you have any other questions.
Posted on Jun 11, 2011
  • 1157 Answers
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 17, 2011
Elite 10 qt pressure cookercode E1 keeps. Coming up on panel on front of pressure cooker. It went heat up at all
try contacting the manufacturer through their website. most have tech support these days
Nov 21, 2016 | Kitchen Appliances - Others
What does e3 mean on the power pressure cooker xl model ppc770/PPC770-1?
No one, including the manufacturer seems to be able to answer that question.
Oct 25, 2015 | Crock Pots & Slow Cookers
Error code (E2-E3)in toshiba washing machine AW1190S
Try replacing lid close sensor...mine one has E2 due to broken wire...
Feb 03, 2013 | Washing Machines
All clad slow cooker won't heat up.
I tried to locate the manual with google, and had luck to find this page, they have the manual!
Enjoy my help.
Sep 20, 2012 | All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
I have acquired a rival rice cooker 4310 and it won't heat up. It appears to be the power cord as it doesn't show any power flow with the multimeter on the heating element or the resistor. no...
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
Sep 24, 2011 | Rival RC61 6-Cup Rice Cooker
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
There is a brown film on the bottom of rice after cooking. Only the rice on the surface can be eaten. Why?
Either not enough water in the pot or heat is too high. Try lower heat setting first... if that does not do it, try adding a bit more water.
Apr 23, 2010 | Oster 4715 10-Cup Rice Cooker
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
