Question about WYSE Computers & Internet
How do i factory reset a wyse model no. Sxo prod id wyse s3o
4 Suggested Answers
SOURCE: Citrix WYSE SXO terminal.
restart client
Posted on Feb 18, 2010
chosen1_39
SOURCE: Wyse S30 resetting to factory defaults
tapping the "G" key upon bootup
Posted on Mar 23, 2010
dontrunrock
  • 36 Answers
SOURCE: How to reset to factory default on a WYSE thin client 1125se
The simplest and most often used method is using Wyse Simple Imager in a PXE setting. This is how most large enterprises deploy images to Wyse terminals.
If this is not an option, there are some other options available. Please refer to this website for some home-brew solutions:
http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
Posted on Oct 21, 2012
Does the wyse sxo have a speaker
No, I do not believe the "S" series (S10, S30, S50 & S90) have any speakers.
Mar 01, 2013 | WYSE Winterm S30 Network Terminal
Tip
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
on Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Oct 03, 2012 | WYSE Winterm 1125SE Network Terminal
How do you reset factory settings for a Wyse V10L? We tried holding down G and it will not go into reset settings. Thanks!
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
Jan 20, 2011 | WYSE Computers & Internet
Ho do the wyse winterm s50 worck? and ho do i, or can i use the?
There is documentation available for free from the wyse website on the knowledgebase. This will detail the full usage of the S50.
It can be used as a local web terminal, or linked to an external server, via RDP (terminal services) or ICA (citrix).
The admin guide (from wyse.com) will help you figure this out :)
Mar 24, 2009 | WYSE Winterm S50 Network Terminal
The wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
WYSE S30 RESOLUTION SETTING TO HIGH
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Computers & Internet Logo
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
