Question about Cell Phones
How do I unlock my handset for my rvmedia tv - Cell Phones
Eu amm uitat codul de tel
Unlock Code
#*7337#
Entering Code instructions
1. Take out the SIM card from the phone and switch the phone on.
2. Enter the unlock code into your handset.
3. Now replace your SIM card and turn the phone on.
4. Your handset should now be unlocked.
Alternative Solution if the above fails
Unlock Codes
Code 1: *7465625*28782#
Code 2: *7465625*28638#
1. Remove SIM Card from handset
2. Enter Code 1 into the handset
(Your handset will display "auto subset lock activated")
3. Enter Code 2 into the handset
a) Enter an alternative network SIM card into your Samsung and reboot.
cool.gif The new network should be displayed in handset window.
c) If the process is repeated with yet another alternative network SIM card,
you may be requested to input a security or pin code to enable the use of
the new SIM card.
d) Enter 00000000 (8 zeros) which should enable the SIM to be accepted.
e) Finally once again enter 00000000 (8 zeros) and this should permanently
unlock the Samsung.
Final alternative Solution if the above fails
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung SGH-i900 Omnia Unlocked Cellular...
Forgot phone lock code for GT-S5233S
Unlock Code
#*7337#
Unlock Codes
the new SIM card.
unlock the Samsung.
Unlock Code
#7465625*638*7337#
Jan 19, 2013 | Samsung Star GT-S5233 Cell Phone
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
How do i unlock my Nokia 6500 slide phone for free
anyway try this two sites they offer you free services
http://unlockitfree.com
http://unlock.nokiafree.org/
here is the unlock page for your mobile;
select country
select service provider
put your IMEI no
that's it
Free Nokia Cell Phone Unlock Codes
1) Unlock Nokia 6600 (Orange, UK)
#pw+399466210777312+1#
#pw+719950237732007+5#
2) Unlock Nokia 3390 (Fido, Canada)
#pw+6595657252+1# or
#pw+4474052474+1#
3) Unlock Nokia 6102 (Cingular, USA)
#pw+939652056653040+1#
4) Unlock Nokia 6820b (AT&T, USA)
#pw+895421713251412+1#
5) Unlock Nokia 6102b (Cingular, USA)
#pw+324556243142742+1#
6) Unlock Nokia 6010 (T-Mobile, USA)
#pw+748900573631603+1#
7) Unlock Nokia 3120 (Vodafone, Spain)
#pw+008923325642375+7#
8) Unlock Nokia 6101 (T-Mobile, USA)
#pw+110464135761655+1#
9) Unlock Nokia 6230 (Vodafone, UK)
#pw+737190152533105+7#
10) Unlock Nokia 7600 (3 Network, UK)
#pw+448917267516205+1#
note: {To get the p push your * key 3 times, the w is the * pushed 4 times and for + is the *pushed2 times. }
let me know if it's helpful to you
Dec 17, 2009 | Nokia 6500 Slide Cellular Phone
Please I need the unlocking code for samsung U600 (Asphalt Urban Gt)
Unlock Code
#7465625*638*7337#
Instruction to fallow
please rate
Sep 06, 2009 | Samsung SGH-U600 Cellular Phone
How to unlock sos
To Unlock your Handset you Need contact your Handset Service Provider.
To remove SOS
Remove the Battery and Sim Card from your Handset and Re insert.
If the Problem Continues,
Try to use other Sim card in the handset, if its working fine then the problem is with your Handset.
If its not working then the problem is with your Sim Card.
Jul 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
Asking me to enter unlock code when i put my sim card
A subsidy is another term for a unlock code. This handset is locked to a ntwork, ie: if handset purchased from orange is would be locked to the orange network. by calling your network provider they can get the handset unlock for a fee. Please bear in mind when doing this you can go to a backstreet shop which can do this for you however, all warranty on handset is void if you need to send back for repair due to the handset has been tampered with. trust me they can tell
May 27, 2009 | Motorola Mobility W375 Cellular Phone
Unlock code nokla n95
Further to your communication with Vodafone regarding the unlocking of your Nokia handset, I have set out the following procedure and unlocking code:
1. With the Vodafone sim card inside the handset
2. Key #pw+129022718795152+1# (The p w and + symbols are found by keying the * key twice for the + symbol, three times for ‘p’ and four times for ‘w’)
3. The handset should then display “Sim restriction off” which means it is unlocked
NB. If the handset fails to unlock, then please do not attempt to enter any sequence more than twice, as you will risk permanently blocking your handset. "
Mar 20, 2009 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
