Question about LG Refrigerators
LG LFC20760ST refrigerator turned off due to doors being left open. I have had this happen in the past and LG instructed me to press certain buttons on the freezer controls that would reset computer.
HVACRH20
  • 237 Answers
SOURCE: Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Posted on Nov 09, 2006
  • 210 Answers
SOURCE: LG Bottom freezer refrigerator LRFD25850ST
You will have to buy a new board to solve it.
Sgt 48
Posted on May 31, 2008
  • 489 Answers
SOURCE: LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Posted on Jun 08, 2008
  • 37 Answers
SOURCE: Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Posted on Sep 02, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
Does the LGLFC20760ST refrigerator come with water/ice dispenser on the door?
Hi and Welcome to FixYa, I am Kelly
This refrigerator does not have in-door ice feature. It also does not have a water filtration system. You should install an external water filter on your ice maker water supply line if you purchase this unit.
Unit details can be found here:
http://www.lg.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC20760ST.jsp
Make sure to click on the drop down menus lower on the page for EACH section using the specifications tab.
Also if you choose the Gallery tab you will see there is not an in door ice feature.
Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | LG LFC20760ST Stainless Steel Bottom...
Hi, My fuse is out on my refrigerator, 2008 model LFC20760ST. The fuse sits right on the circuit board and I'm not sure how to release it. Can you help?
the fuse is soderedto the board and is not to be replaced as a replacement part . but that doesn't mean that you cannot replace it . it may blow again and if so find out why . the board may be very costly and the fuse is not . so it's worth a try .. mm
Sep 23, 2010 | LG LFC20760ST Stainless Steel Bottom...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
I am looking for a refigerator either side by side with no water and ice or a bottom freezer refridgerator needs to be 31 inches wide.
Have you checked out the LG model LFC20760SW French door with no external dispenser, which fits a 30 inch wide opening? (PS. Buy from a small dealer, not a big box or Sears if you want good service over the life of your product) Check where to buy at with your zip code http://www.lge.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC20760ST.jsp but avoid the big guys. You may have to go to a 10 or 20 mile radius to find a servicing dealer, but it will be worth the effort.
Jan 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
Fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
I have condensation dripping right behind where the french doors meet on the ceiling of fridge, how can i solve this problem?
Possible that your door gasket is not sealing very well and therefore condensation forms in this area?
Jul 02, 2009 | LG LFC20760ST Stainless Steel Bottom...
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
