Question about Refrigerators
Nothing is working on the refrigerator - Refrigerators
Refrigerator has power supply, but nothing works
Hi fred_n705, thank you for your post!
From what you have described, it sounds like you either have a communication problem with the control board, faulty temperature control, or sealed system issue. This is not a typical DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Best regards!
Feb 09, 2014 | Frigidaire FRS26KF5C Side by Side...
My whirlpool side by side suddenly stopped working, only the interior light would come on. Nothing else was working. A couple of weeks prior to this, food started freezing in the refrigerator, then...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 12, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Freezer keeps defrosting and nothing is stay frozen and nothing is staying cold in fridge either
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 20, 2010 | Frigidaire FRS26KR4A Side by Side...
Amana abl2227fes freezer works but the refrigerator does not
If the board is not opening and closing the damper from the freezer to allow air flow, the board will need to be replaced. If the control does make any of the damper parts move then it would be a mechanical problem with the damper conrtol linkages.
Sep 10, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Holiday Refrigerator NT156M stopped working.
check to see if stuck in defrost locate timer and advance it
Apr 17, 2009 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
