Question about Cell Phones
Sometimes my phone doesn't ring when I get a call. When I turn on the speaker, it turns the speaker off. It's like there's an intermittent bad connection to the speaker. What do you suggest I do?
5 Suggested Answers
  • 306 Answers
SOURCE: intermittent starter problem, sometimes turns,
Many European cars have relays that trigger the starter,maybe yours is bad? New battery and new starter? Need to check battery connections to vehicle especially ground wire to engine block. Starter face and flywheel housing have to be clean for good ground connection.
When it won't start do you try key numerous times? Sometimes (rarely) bad keyswitch.
Posted on Mar 10, 2010
starskl
  • 26 Answers
SOURCE: My phone doesn't ring or vibrate also the
Go to settings again , swipe towards your left ... under application select phone . check call forwarding settings . It should be OFF . Give me a thumps up if it works .
Posted on Aug 04, 2011
SOURCE: sound doesn't work tried settings
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
  • 68 Answers
SOURCE: My setting for ringer is turned on, but my phone doesn't ring when someone calls me???
It could be that your selected ringtone is inaudible. Go into your settings and test the selected ringtone for calls. If you can't hear it, try another. Also check your ringer volume setting. It may be all the way down.
Posted on Nov 16, 2012
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
Nov 27, 2012 | NEC Dterm DTP-2DT-1 Phone
One speaker doesn't work on my bose wave radio/cd?
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Nov 04, 2012 | Bose & Wave& Music System
My Iphone4 is ringing very quietly and My microphone doesn't work
It sounds as if your phone got wet or your speaker is broken, I suggest that you will take it to the lab
Jun 17, 2012 | Apple iPhone Smartphone
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
My uniden tect1580 doesn't ring
First thing to try is while the phone is in "On-Hook" mode, press the up key on the handset several times, you should hear a beep each time you press the button and the display should show "Ringer Volume" with a graduating series of bars. If the display shows as above, but you do not hear any rings, try pressing the "Speaker" button and listen for the dial tone. Most of the time on these phones, it is a simple matter of turning up the ringer volume, but sometimes, the handsfree speaker (Which also acts as the ringer speaker) goes bad. If the speaker is bad, it is a fairly easy replacement if you are handy with a soldering iron.
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
One speaker works all the time the others only sometimes
Could be intermittant wiring issue or the speaker itself.
If you have another spare car speaker you can hook up temporarily, I'd start there. Disconnect one of your "bad" speakers and hook up a known good one. If the temp. speaker works OK all the time, then you know you wiring is okay.
Let me know if more ?s!
Mar 22, 2009 | 1996 Chevrolet Cavalier
Sometimes rings, sometimes not
your phone might have fallen from your hand and the internal jack of your speaker have got damaged. you should readjust your speaker from servicing center or just change your speaker of your phone
Jul 25, 2008 | Motorola Mobility V365 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
