Question about Power Computers & Internet
I have a nitro BMWX-5392b, my cd won't come out. I tried holding down power and eject, but it's still stuck. I need it out but how? HELP
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
  • 9 Answers
SOURCE: cd stuck
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Posted on Jun 07, 2008
  • 651 Answers
SOURCE: CD Changer is stuck
drop the faceplate, there should be a tiny hole you can push a paper clip in. push in a little bit and it should eject. good luck
Posted on Dec 01, 2008
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Posted on Jan 24, 2009
SOURCE: help cd stuck in my ps3 console
I have the problem too, only that.. I can play for instance GTA IV wich i do all the time, but my Call of Duty Modern Warfare 2 is stuck, I KNOW it is inside there, if i shake the console carefully i can hear the cd but i can still play other games, its like the cd dissapeared
Posted on Jan 19, 2010
Looking for the plug in harness for a Nitro bmwx 33.2 where can I get 8th?
BMWx-33.2W :: 3.2" Widescreen Head Units, Digital TFT ... > Car Electronics > Car Video
HEAD UNITS Digital TFT One DIN Widescreen 3.2" BMWX-33.2 By Nitro. ... Camera Input (without camera); 4 Channel High Power Output; Plug-In Harness ...
One Din with Monitor - NITRO-AUDIO
BMWX-3.2 3.2" Digital TFT One DIN Widescreen/Touch Screen ... Plug-In Harness • NTSC/PAL System Compatible ... BMWX-33.2W 3.2" Digital TFT One DIN ...
NITRO BMWX 5393BT Car Stereo Bench test - YouTube
? 1:36
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
Dec 09, 2015 | Cars & Trucks
Nitro car stereo manuals
Need settings code for an Nitro BMWX-4756 300Watt 7" Touch Screen Monitor In Dash Din DVD CD AM FM for the gps, settings it's a 4 digit code to change GPS settings
May 01, 2015 | Nitro Bmw-4741t In-dash Touch Screen...
Can't insert cd
probably there is a stuck cd inside!
Aug 27, 2013 | Nitro BMWX-4673A
Cd stuck in player
Steps as follows
Take a blank/useless CD (such as AOL free trial CD's, you can get them in a plethora of amounts in Best Buy) and place it about 1 inch deep into the slot.
Press the 'Eject' button and gently wiggle the CD around. If this doesn't work, repeat and try to get the blank CD below the the jammed CD, and gently pry the target CD upwards. Also, a good pair of tweezers works well to grab the CD and pull it out.
Sometimes, unusual amounts of pressure may be on the unit, behind the dash itself. Have a professional or a friend that you trust remove the dash unit and try steps #2 and #3.
Reduce electrocution risk by disconnecting all power supplies from the CD player and make sure any electrical charge has been removed.
Feb 15, 2013 | 2008 Dodge Nitro
I put pictures in the cd but now it won't eject. It dot stuck inside. I could not eject even if I clicl computer then click eject, it won't eject
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
Jul 10, 2011 | Fujitsu LifeBookS6120 Notebook
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
We put a bluray disc in the PS3 and the disc is stuck and the console will not eject the disc and will not stay on. We have tried holding down the power button, holding down the eject button and nothing...
switch off power at the back. hold down eject button, keep holding, turn power button at the back to on. console fan will spin very fast ( at this time take your finger off the eject) then goes back to normal. try now to hold eject button for more than 9 sec; it will then eject your disc. if this dont help check this site:
PS: most likely, you already have a problem with your Blu Ray laser (life span expired) or hopefully you will need to just re-allign your CD drive mechanics. dont open your console if you still covered with sony waranty. otherwise; give it a try; many youtube videos will show you how to do that.
Good luck
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
I bought a vehicle that has 2 nitro amps installed in it and the sound is crappy... i need the installation instuctions for the following.... BMWx-486 BMWx-483 help,help!!!
dude buy a new system for one never heard of a nitro and for two if you dont know **** about systems and your buying a beamer then you should have enough money to get a new better system installed
Aug 15, 2009 | Car Audio & Video
Computers & Internet Logo
29 people viewed this question
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
