Question about Kenmore Refrigerators
What does it mean when Kenmore Elite chest freezer flashes code FF
SOURCE: error code er ff on my kenmore elite bottomfreezer model 795.7756
I fixed it. ER FF is "Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed. This fridge is poorly designed and is not designed with air gaps or enough air gaps to allow air behind the back panel of the freezer where the fans and condenser coils are located thus causing ice to build up around the fan and it's ability to spin. The evaporator fan helps cirulate the cold air generated by the condenser coils.
The fix is (1) defrost your refrigerator which means you'll loose all your food if you don't have another unit to keep the food in until it's done defrosting or (2) to dismantle the entire freezer by removing all the trays and railing so that you can pull the back panel far enough to get the front end of a hair dryer over the top lip of the panel to melt the ice. My unit had ice build at the top right and left corners behind the panel. I opted for the latter and didn't have to throw any food away.
This is going to be an annual chore if I want to keep this refrigerator. We should all ban together and call for a recall.
Posted on Dec 24, 2008
dealt_soul
  • 296 Answers
SOURCE: Kenmore Elite ER FF
Possible sesor error. Unplug for bout 10 min then plug back up.
Posted on Jan 30, 2009
rylee_smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: my trouble codes are Er FF on my kenmore elite
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
Posted on Sep 25, 2010
What does it mean when the Kenmore Elite chest freezer flashes FF code
That means the fan has not started like it is supposed to. Unplug the unit from power for a couple of minutes and try again.
Apr 20, 2017 | Kenmore Refrigerators
FF 6 code
What is the model number?This error code FF indicates a problem with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced.
Nov 10, 2012 | Kenmore 19.7 cu. ft. / 558 liter Chest...
What er ff mean at Error message on display of Kenmore Elite Bottom Freezer Refrigerator
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sears brand CHEST freezer had beeping noise. I changed the 9volt battery. It still beeps every 10sec. and flashes the number 6 and FF
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Kenmore bottom freezer control panel error ER FF
it is probably the defrost controller and the board on the back. The code means your freezer fan is not working
Nov 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My trouble codes are Er FF on my kenmore elite
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite ER FF
Jan 30, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
