Question about Dishwashers
My dishwasher spray arm had melted and was causing the dishwasher to leak. I bought a new spray arm, but when I manually turn it, it will still contact the heating element. What could be causing this?
  • 1 more comment
  • Brad Brown Apr 20, 2017
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model number
  • Anonymous Apr 20, 2017
    Sure, it's a kenmore dishwasher, model number 587.15272204A
  • Anonymous Apr 21, 2017
    Anyone have any suggestions? I don't want to risk melting another spray arm.
5 Suggested Answers
Joe_Rex
  • 114 Answers
SOURCE: dishwasher problems
TURN POWER TO OFF ... REMOVE THE LOWER RACK. THE SPINNING SPRAY BAR USUALLY WILL LIFT SRAIGHT-UP AND OUT ... INSPECT TO SEE IF ANY THING IS IN THERE TO PREVENT IT FROM SPINING FREELY ... THEY SPIN BY WATER PRESSURE SO THE NEXT THING TO CHECK IS THE WATER SUPPLY VALVE (MOST OF THE TIME IT IS RIGHT UNDER YOUR SINK.) AND THE STARAINER is LOCATED WHERE IT CONECTS TO THE DISH WASHER. MAKE SURE YOU HAVE A BUCKET AND RAGS HANDY FOR SPILLS... CAREFULLY TURN THE VALVE OFF AND REMOVE THE COMPRESSION FITTING NUT THAT IS ON THE "SIDE CLOSEST TO THE WASHER".... THEN CRACK THE VALVE OPEN AND FILL THE BUCKET UP A FEW TIMES TO ENSURE GOOD WATER FLOW. TURN VALVE "OFF" AND GO TO WERE THE LINE OR HOSE CONNECTS TO THE WASHER. REMOVE THE CONNECTION ... INSIDE YOU SHOULD FIND A STRAINER THAT MAYBE CLOGGED UP. CLEAN-IT AND MAKE SURE TO TIGHTEN ALL THE CONNECTIONS BEFORE STARTING A TRIAL RUN. NOTE: THERE IS A SOLENOID INSIDE THE MACHINE THAT CAN STICK AND GET CLOGGED BUT USUALLY ITS THE VALVE OR THE STRAINER. GOOD LUCK AND STAY DRY ... Joe_Rex
Posted on May 01, 2007
vest6
  • 196 Answers
SOURCE: How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
Posted on Jan 10, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
  • 423 Answers
SOURCE: Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Posted on Apr 01, 2009
We have a fridgiaire dishwasher and the heat is there but when we put a tablet in it and turn it on it doesnt spray water eonough to melt the tablet and we always find it on our dishes when the cyale is...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 18, 2011 | Frigidaire Professional Series 24 in....
Bottom sprayer not turning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Nov 11, 2010 | Magic Chef CDB1500AW 24 in Builtin...
Upper & lower spray arms do not turn. Runs cycle OK, water comes in and goes out.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Oct 26, 2010 | Maytag MDB5100A Dishwasher
Run times are long and water is not getting hot
heatman101
256re
Apr 14, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
The cycle did not complete,the bottom spray arm (the tip) melted along with some plastic utensils (knife handles). Water come out of thee front door.When starting the washer again, the top and bottom spays...
The handles slipped down keeping the spray arm from rotating thus causing it to rest against the heating element. It won't wash because of the hole in the bottom spray arm. You have to replace the spray arm before nything else can be determined.
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My dishwasher leaks on occasion, and leaves scuz on the dishes. Any suggestions on what to do? Bosch quized me on the detergent I'm using and I've had a repair man out at least 4 times.
heatman101
Sep 24, 2009 | Bosch SHE45M06UC Built-in Dishwasher
Dishwasher is not cleaning as it used to. It does not even melt the soap.
heatman101
otiu,
Aug 01, 2009 | Magic Chef DU6500 Dishwasher
Bottom spray arm not turning
heatman101
rthd
Jun 09, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishes not clean and leaks sometimes
heatman101
Feb 03, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
DISASTER! PLEASE HELP. WOKE UP THIS MORNING & DISHWASHER MELTED!!!
Amsanta, sounds like something got hung up on the heating element, stopped the lower spray arm and things started to melt. The lower spray arm, part number, 154414101 is easy to change out. There is also a lower spray arm support 154294101, don't know if you will need that. I believe on your model the lower spray arm just snaps on. There is a tab on the filter screen that will rotate to unlock and the filter screen will lift out. Now the lower spray arm support is accessable. If it's less than a year old, you may be able to get it fixed under warranty. Catriver.
Jun 09, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
