Question about The Office Equipment & Supplies
76-73 left panel, the error of the receiver how do u fix it
DCER INDISPLAY
This error usually means that your receiver has detected a wiring problem. It has shut down to protect the electronics in the unit. Somewhere, there is a section of wire that has damaged insulation or has come loose. Two wires are in direct contact with each other or a wire is touching the metal of the car.
You'll need to locate the damaged wiring and insulate it or otherwise repair it. After you fix the wiring, you may need to press the Reset button to clear the error. (The location may vary. For most Kenwood receivers, the Reset button is a very small button below and towards the left side of the volume knob.)
If you post the model and manufacturer of the audio receiver, I may be able to give additional information. If the error persists after you fix the wiring, your receiver may have been damaged. In that case, the unit needs professionally repaired.
I hope this helps.
Oct 03, 2015 | Car Audio & Video
Tip
HP All-In-One can send but cannot receive fax or can receive but cannot send
One of the most common problems with HP All-in-One Printers is that they can send out fax but cannot receive or they can receive fax but cannot send. Now, what more could possibly be the problem if you are sure that your connection cables are correct and properly setup? Well, most people don't know that this is more often than not, caused by the ECM feature of the fax.
ECM or Error Correction Mode is used by fax machines during transmission. This feature is used to eliminate transmission problems especially when you have a "dirty" or noisy telephone line or a very poor signal can result to fax failures. ECM mode, when is turned ON is supposed to check for errors and glitches and is supposed to make the reception or transmission of faxes come out successfully.
However, for some reasons, the ECM mode is not supposed to be performing well with its feature. Especially if the user has a problem with the telephone line, the more that they cannot receive or transmit a fax. It is then recommended that your HP All-In-One printer's ECM fax settings be turned OFF. To do this, follow the steps below:
1. On your printers front control panel, press the button with the wrench symbol; this is the Setup button.
2. Press the right > or left < arrow until you see Advanced Fax Setup then press OK.
3. Press the right > or left < arrow until you see Error Correction Mode; again press OK.
4. Press the right > or left < arrow until to select Error Correction Mode OFF. Press OK to confirm.
That's it! You may now try to send out a fax or ask a friend to send you one.
on Mar 07, 2010 | Office Equipment & Supplies
Tip
on Dec 02, 2009 | Office Equipment & Supplies
How do i fix my drm activator
If you are receiving the DRM activator error message do the following to correct the issue.
1 - Left click on Start
2.- Right click on Computer
3 - Left click on Properties 4 - Left click on Advanced System Settings
5 - Under Performance click on Settings
6 - Left click on Data Performance Settings
7 - Click on TURN ON DEP FOR ESSENTIAL WINDOWS PROGRAMS AND SETTINGS ONLY.
8 - Click on Apply and then OK.
UAC: (User Account Control)
Open up Control Panel, and type in user account into the search box. You'll see the link for "Turn User Account Control (UAC) on or off". Click it. Uncheck the box, and reboot your computer
Aug 18, 2012 | Microsoft Windows Vista Home Premium with...
I received a new printer today, I installed the software and ready to test print page. I get error message that the carriage is stalled. I found a procedure on HP web site that to fix problem, but it...
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Jul 14, 2011 | HP H470 InkJet Photo Printer
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance: http://www.lexmark.com/publications/pdfs/4200/eng/frameset.html
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
I am receiving an error msg on my Panansic, Panafax UF-333 machine. The msg is a code=316, error msg. What does that mean and how can I fix it?
Unplug the machine and move the ink cartridge to the all the way to the left.
Take a letter opener and knock off the column of dried ink that has built up where the cartridge was sitting.
If this does not fix it, the main board is defective.
Dec 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
Xerox Workcentre Pro 215
This should resolve that fault code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Ps2 error message
not sure but check the memory card or the inside to the left see what you can fix
Dec 07, 2007 | Sony PlayStation 2 (PS2) Console
No Analogue or digital channels!
Hello - I just posted something too. Not sure if its the same problem as yours. If you get a response from elsewhere, please let me know. I'll do the same. In our case we have a blank screen with a bar running across the top of the screen reading 'No signal' on left side and 'C611' on the right side. The 611 might be the last channel we were on !
Mar 07, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
