Question about Golf
On a 36 volt ego golf cart forward/reverse switch what position does the s1,s2,a1and a2 bolt to the switch? For example of the four bolts on the switch witch wire goes to the bolt in the 12 o'clock ?
  • 100 Answers
Looking down on the f/r switch , the bottom contact is A then moving clockwise you get B, C , and D.
So C (top) would connect to A2 of the motor and also to A2 of the controller if there is an A2, Some controllers do not have an A2.
B would go to S1(F1) of the motor.
A would connect to B+ of the controller.
D would connect to S2 (F2) of the motor.
Posted on Jun 05, 2017
SOURCE: radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Posted on Aug 17, 2008
weblord
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
  • 582 Answers
SOURCE: I've got a John Deere SST-18 riding mower. I've
GO ON LINE TO JOHN DEERE PARTS YOU CAN DOWN LOAD PARTS DIAGRAMS AND WIRING DIAGRAMS ALSO. CHECK THE PLUGS AN THE WIRING HARNESS AND MAKE SURE THEY ARE CLEAN. WITH A VOLT METER YOU CAN CHECK AND SEE WHAT VOLTAGE YOU ARE GETTING TO THAT RELAY. I DON'T HAVE A DIAGRAM TO LOOK AT BUT IF I CAN FIND ONE ONLINE I'LL LET YOU KNOW. HAVE YOU CHECKED FOR A SECOND RELAY
Posted on Sep 15, 2009
  • 34 Answers
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Posted on Apr 24, 2010
SOURCE: Have 36 volt club car w/coils
I DON'T HAVE HELP FOR THIS BUT.................WITH MINE THE RELAYS SEEM TO JUST CLICK. DOES FINE IN REVERSE BUT WILL NOT GO FORWARD. I DID GET A WIRING DIAGRAM BUT CAN NOT TELL FROM IT WHAT WOULD BE WRONG. WHAT ARE THE CONNECTIONS ON THE MOTOR. THERE ARE FOUR. WHAT IS WHAT THERE? THANK YOU TRACY
Posted on May 13, 2010
My golf cart has six, 6 volt batteries connected in a chain, positive to negative throughout. Can I connect an auxiliary light of some type to this power source?
the cart is wired for 36 volts operation so you would need a 36 volt bulb
or
you could put the wiring for a 12 volt bub across the terminals of 2 batteries so the negative wire will be on a negative terminal of the first battery and a fused positive wire will be on the positive of the second battery
the batteries are connected in series so the sum total of the voltage is the sum of all of the batteries
by selecting 2 batteries in series you are using the sum voltage of 2 batteries
Nov 24, 2017 | Golf
Have strong current draw with reverser in either position key off?
The key should turn everything off except for the reverse buzzer. In forward position it should turn off.
Sep 22, 2017 | Golf
I own a Yamaha 2011 YDREX 48v golf cart. How do you troubleshoot the controller with a voltmeter. Once you buy them, you can't return it. Thanks,
I don't know how to check that controller, I always check everything else then replace the controller. I start by checking to see if the solenoid is working and the reverse buzzer. If they are then I check the motor. You have to disconnect the main batteries then disconnect the four wires off the motor. Take a jumper wire and connect to A1 and F1 then to 16 volts. Another jumper wire will connect to A2 and F2 then to16 volts. One should be negative and the other positive. In this setup we are applying the same voltage to both coils of the motor at the same time. If the motor turns it's good.
Aug 30, 2017 | Golf
Cart wont move just hums was working ? 85 Ezgo 36 volt
If all wiring is factory then check batteries under load. If all good then test motor. With rear wheels off the ground, disconnect the main pos and neg wires from the batteries. Then disconnect the four wires from the motor. You can use a voltmeter to measure the value of the two coils of the motor. Measure between A1 and A2 then S1 and S2 ( sometimes F1 and F2) Should get 1 or 2 ohms. If that good then jumper A1 to F1, connect A2 to 12 volts and F2 to 12 volts, one neg and the other pos. You will get a spark but the motor should start turning if good.
Jul 26, 2017 | Golf
Ezgo 36 volt buggy i have 2 one in good running order other one not going now solenoid not clicking have swwapped solenoid and controller to good running cart and it works problem cart still problem
Hope it's fixed by now. If the solenoid is not clicking then one of your switches is bad or wiring. Check the key switch, forward/ reverse micro switch, and the switch in the floorboard that is connected to the gas pedal.
Apr 19, 2017 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
How to wire a 12volt lights to a 36 volt system on an E-Z-Go golf cart
all you have to do is run the positive wire from the lights to the positive post of one battery and the negative wire to the negative post of the same battery. You will be using just one battery to power your lights. Hope this helps
Oct 19, 2010 | MK Battery Golf Cart 12 Volt Sealed Gel...
Apr 09, 2010 | 1993 Acura Vigor
Recheck your battery wiring. The batteries should be wired in series, neg to pos to neg. I believe one of the batteries behind the driver's side is the main negative and one on the passenger side is the main positive. There is usually a #6 green wire coming from the for/rev switch to a positive battery post, however , it might be a different color, but that one is the reverse wire, It can be on any positive post, just count the number of batteries between green wire and main neg, multiply by 6 and that would be total reverse voltage. If wired correctly all 6 batteries are used for forward.
Jul 13, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Golf Logo
677 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
