Question about Sewing Machines
My bobbin will not load after my needle broke.
Why won't my bobbin thread come up after changing a needle?
  • Sewing Machines Master
  • 11,160 Answers
More than likely, when the needle broke, it knocked your machine out of time, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread. Search for sewing machine timing or take it for service.
Posted on Apr 21, 2017
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
  • 3 Answers
SOURCE: Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
ladya2004
SOURCE: needle thread will not pick up bobbin thread
I finally had to take it in for repair at Sears
Posted on Apr 01, 2012
SOURCE: sewing machine needle won't go down to catch bobbin thread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly
also make sure the thread has not come off the thread take up lever
if none of these suggestions help, then you should consider
taking the machine to have it service, to see if it's out of time
Posted on Jul 31, 2012
I have a CG 500. First time sewing in 30 yrs. Making a baby quilt, got through most of until the needle broke. I replaced the needle with the suggested type, now it stitch.
You don't specify exactly what is happening when you try to stitch.
Remove all the threads from the machine, RAISE the presser foot and rethread from the beginning (verify the thread path is correct and the bobbin is loaded and thread correctly). If the threads are not connecting, it could be the incorrect needle. However, given that the last needle broke, the machine may have been knocked out of time (happens frequently with broken needles). You can search for sewing machine timing or take it for service.
Feb 09, 2017 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
I broke a needle and now it wont pick up bobbin tread
Hello
Make sure the needle is facing in the correct direction,stitches don't form, or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail after threading the needle.
make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case.
Also check if the needle is not properly installed in the needle bar,the machine is not threaded properly or the machine needs adjustment or repair..
Feb 12, 2011 | Euro-Pro 416 Mechanical Sewing Machine
Needle broke and i changed with the same number now it is not picking up the thread and does not stitch
you said the needle broke, did you check in the needle plate where the feed dogs are if there was any needle fragments
also check in the bobbin area for needle fragments, take the bobbin case & bobbin out & clean the area
Oct 21, 2010 | Singer 8280 Mechanical Sewing Machine
Needles keep breaking & bobbing wont feed thru
Pam M.
May 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Dec 28, 2008 | Baby Lock Ellure
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
