Chicago electric hand held oscillating multifunction power tool item number 62866 accessories
4 Suggested Answers
  • 373 Answers
SOURCE: hand held diagnostic tool
OK...
If the scann tool is powered with the power of the Vehicle.
It's mean the connector is missing a power .
To fix this you need to check. the following
Check the " CIG" fuse 15amp. This fuse give +12 v to the cigarret lighter and OBDII diagnostic connector.
Is the Orange Wire of the OBDII connector and PIN # 16
The Ground is the PIN # 4, black wire, and PIN # 5, black/white.
Be sure of this wires are correct fix if any need,
after try to sacn again or see if there a power when you connect the Scann tool.
OK.. I hope this help to try diagnostic your vehicle,
Thank you for use fixya.
any further info, let me know.
Posted on Aug 13, 2008
  • 172 Answers
SOURCE: Where can I find a blade bolt for a Chicago
Take the model number and serial number to Ace Hardware. They should be able to look it up for you and get the correct bolt in.
Posted on Jan 16, 2010
VacuumRepair
  • 438 Answers
SOURCE: Replace accessory hose
i There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Posted on Apr 15, 2010
How do I load brads into my chicago electric
I'm looking for the same thing, cause they seem to big
Mar 02, 2013 | chicago electric power tools 3-In-1...
What are the advantages/disadvantages of electric vs. corless oscillating multifunction power tool?
cordless tools are great because you don't have to always find an outlet, or even worse, extension cords, constantly. However, on a job where you will be using the tool all day, a cordless tool may not maintain the power that you wish you had
Jan 23, 2013 | Tools & Hardware - Others
Where can I find a blade bolt for a Chicago Electric Power Tool Chop saw?
Jan 16, 2010 | Ace Hardware Ace Chop Saw Cut - Off Blade
What are the inserts used for and how do you use them?
This ia a very specialized tool and I had the same question at one time, noone could tell me, ssooo! I put each one on and tried it out. The main thing I found out was differant thicknesses of wood was a big issue, time and patientence and using it as a power carving/sanding tool made it a very time saving tool. Each insert has it's own special use only learned by trying each one and learning what you can do with each one in curved items from clocks to steering wheels and more, hope this has helped you a little. Have Fun, and remember little/light strokes do the trick!
Jul 08, 2009 | Porter Cable 121 6 Amp Hand Held...
Information on usage of oscillating saws
My "solution" was that I finally realized that Fein and Rockwell do not believe in providing service, so I had to look elsewhere. I called Harbor Freight, was able to get the advice and information I needed, and purchased a oscillating saw made by Chicago Tool. I would have preferred a Rockwell Sonicrafter, but after experiencing Rockwell's attitude towards potential customers, I realized that I would not be able to get the help I needed now, nor in the future should I have bought their product.
One good thing came of this experience: I learned of your servixe, and I am bookmarking your site.I'm sure that I will be making use of it some time in the future.
Feb 12, 2009 | Fein FMM250 Start Multimaster Oscillating...
Ratchet Question
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools.
Aug 27, 2008 | Chicago Skates Chicago Pneumatic 7830 3/8"...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
