Question about Sharp Office Equipment & Supplies
I have a Sharp AR-BC320, how do I change the language to english on the machine?
SOURCE: Looking for a reset code for sharp ar-bc320
The default web page user name and password are admin and Sharp case sensitive.
Posted on Jan 27, 2009
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
SOURCE: Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Posted on May 20, 2009
  • 6 Answers
SOURCE: Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Posted on Feb 05, 2010
hamzaskilltd
  • 316 Answers
SOURCE: I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Posted on Sep 20, 2010
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
How do i clear a F9-00 code for the sharp ar-bc320 copier?
Put the machine in test mode with the following key sequence:
P - * - C - *
then, 14-Start ... Execute ... Yes
CA to reboot the machine. For good measure, shut the power off, wait, and turn it on.
PS. - Get your copier on its' own outlet and share it with Nothing!!
Jun 30, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp copier ar-bc320 error code??
Apr 20, 2009 | Sharp Office Equipment & Supplies
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Manual for Sharp AR-BC 320 All in one copier
http://www.sharpusa.com/files/cop_man_ARBC320.pdf
Aug 05, 2008 | Sharp AR-BC320 All-In-One Led Printer
The default key operator access code on that machine is 00000
with this code you can enter network settings and change ip and subnetmask to your new requirements.
If this doesnt work you can get keyop password by entering simulation mode and get service report which has user code on it.
Apr 12, 2008 | Sharp AR-BC320 All-In-One Led Printer
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
