Question about Sony Audio Players & Recorders
Bought brand new Sony TV and Sony Sound bar. Hook up seemed to be simple, but at 100% volume, it is the same as 50% using the TV speakers. Using their recommended HDMI setup with ARC
  • 63 Answers
SOURCE: Set up the Panasonic SC-PT450
Are you sure you're using a source material that is surround sound? Most TV broadcasts are still only stereo.
Also with surround programmes, the rear speakers are only used for the surround effect so will only make sound when the sound source is supposed to be behind you.
Posted on Jun 25, 2008
SOURCE: installing wii to panasonic viera 50'' plasma
I could resolve the issue. First of all, the wire supplied with the wii is not compatible with your TV. This 3 point connector, will end up giving you b/w screen. So you need to buy the 5 pin connector. I bought from Frys for $19.99. The box says "High Performance Component HD A / V Cable" (like this one: http://www.bizrate.com/wii-accessories/oid875654433.html )
In any case, do below
1> find the 5 point input row (vertical) on the back of your TV.
2> Insert the connector, in the sequence of Red pin being the bottom most. If its 5 pin connector, then start from the lowest point on the back of TV. If its 3 pin connector, use the top 3 points, on back of your TV. Red always being the bottom most in sequence.
Once again, buy the 5 pin connector, as inserting these pins on the back of your TV when the TV is already mounted on wall, is the hardest part to do...so why to waste your enerty in doing again and again. I am sure you would not like the black & white screen coming with 3 pin connector.
Posted on Dec 27, 2008
leme
  • 25 Answers
SOURCE: PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Posted on Jan 02, 2009
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
mlapres
  • 757 Answers
SOURCE: Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Posted on Jan 18, 2010
Testimonial: "Thank you excellent report spot on with the hook-up. Will buy new receiver. John McMullan."
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
I have a samsung plasma 50" tv, how do I hook it up to this sound bar? I tried to hook it up using the rca jacks and it didn't work.
Near the Audio / Video inputs on your tv, you should see a "headphone" jack or it may be labeled "Audio Out"
some sound bars plug into these jacks using standard heaphone jack.
Other sound bars may need to be connected to the device your using on your tv. (DVD player, cable box, etc.)
Tv speakers can then be disabled in the "Audio" menu of your tv.
Dec 02, 2014 | Samsung Televison & Video
My TV has terrible sound at volumes where we can actually hear the TV. It gets warbled like the speakers are bad.
The TIVO system is not a problem. I have it and it works fine. Make sure all the cords are plugged and screwed in tight.
Nov 06, 2013 | Televison & Video
I just bought the coby csp96 surround sound package and am having trouble hooking everything up. It came with the dvd player to hook all the input cords to, which i did. Everything is working accept when i...
there is a nobb on the subwoofer, one is to dial down or up the sub (noob1) , and the other is to dial up or down the 5.1 speark (noob 2). turn noob 2 to the left to dial down the sound, first time i got my setup it was totally down, btw the 5.1 works wonderous if you use a home theater system. Iam using a 1,000watt sony home theater system. 100/200watt RMS per channel at 5 channel those little speakers really can handle well, I never experiance any blow outs :) Coby outdid themselfs with this system
Sep 05, 2010 | Coby CSP-94 Speaker
No sound
When my sound output set to off and I use the remote to change volume; it tells me speakers off.
Try a different output method: hook up headphones, other speaker type... these answers should help you find a solution.
Feb 27, 2010 | Televison & Video
Volume
I am no pro but I hooked speakers up by using the ourputs at the back. You have to plug into a reciever or amplifier though first. You cannot just hook external speakers up mwhich is what I believe you are doing...
Rich
Jan 19, 2009 | Toshiba 32D46 32" TV
Lg 47 inch tv sound
We had the same problem of pathetic sound quality and volume with a sony brava. Thats just the way they make tv's these days because most people buy a surround sound system as well. We bought logitec computer surround sound speakers for about $140 and plugged into the ear jack, problem solved, we have heaps of volume and stacks of bass.
Dec 21, 2008 | LG 47LC7DF 47 in. LCD HDTV
Help
few tv sets have extra head phone volume option but many has either way, I mean if you put head phone, speakers will be off.
I dont know the model n make of your tv set.
May 27, 2008 | Sony MDR-RF970RK Headphones
Can these be hooked up so you can hear the tv external speakers as well?
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
Qosmio G40. DVD playback - volume much too low with Vista
Vista users try this.
Control Panel -> Sound -> Speakers. CLick the levels tab and adjust the playback control i had to adjust mine from 50 to 100. now sounds like it did in XP
Mar 21, 2008 | Computers & Internet
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
