Question about Refrigerators
Our refrigerator question does it have a rest button
Why isn't display working?
During black out the chances for a control board failure are much higher. What is the fridge model number?
APPLIANCE 911
Nov 15, 2015 | Refrigerators
The centre of my sided by side refrigerator is really hot and the temperature reste button keeps beeping
make sure the thing can breath ie its getting plenty of air and vents r not blocked
Apr 13, 2015 | Refrigerators
Right 8 on refrig/power cool button is blinking and won't reset
Samsung 8888 Display Panel.
To reset, press, Energy Saver & Display Panel buttons, simultaneously, and hold for 10 seconds. A beep will occur. The refrigerator will run diagnostics from there. Replace all your favorite settings.
No worries the refrigerator defaults to preprogrammed cooling and freezing after the power comes back on. Your water dispenser and the rest of the extras are dependent on the command prompt display. I placed these directions in copy within the pages of my favorite cook book. Never to be without the solution again.
Mar 23, 2014 | Samsung RF267AERS French Door Refrigerator
Reset water filter seconds hold jenn
Your owners manual should tell you how to rest these buttons. When your filter button lights up press it once it will ask you to confirm and that's it.
Aug 10, 2013 | Maytag MCD2257HES Side by Side...
How to rest the water filter after I replaced the filter?
Should be a reset button on the despensor panel or you may have to push the refrigerator door switch 5 times if filter light is in Refrigerator.
Jun 03, 2011 | Frigidaire FFUS2613L Side by Side...
I have the frigidaire refrigerator & I replaced the water filter ,how can I rest the water fliter into green light?
Press and hold the filter reset button on the front of despensor 10-15 seconds until the green red and orange lights come on.
Jun 03, 2011 | Frigidaire FRS26RLECS Side by Side...
My refrigerator and freezer are not working when i plug it in it sounds like something in the back is clicking on and off. is there a rest button?
one thing can cause the clicking noise, the ptc overload relay on the compressor is making this noise and needs replacing,it simply unplugs off the compressor and the replacement plugs in these are available at most appliance repair dealers
Jan 09, 2011 | Estate TS25AGXRD Side by Side Refrigerator
My fridge is not makin ice. i put in a new filter and the water works but the ice is not making..and the button is switched on
normally there is a reset that has to be pressed for about three seconds in order to rest the unit filter system.the button may be located somewhere the filter change light is.
Jan 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
I have a sub zero 690 series refrigerator. The display shows codes 34 01 and then EC 24 Any idea what this means? Thank you
DEFROST UNDER HEAT IS THE CODE DESCRIPTION. IF YOU HAVE A BELL BUTTON HOLD IT 15-20 SECONDS TO CLEAR. IF THERE IS NO BELL BUTTON POWER OFF THEN POWER ON TO REST AND SEE IF CODE COMES BACK AND THEN CALL FOR SERVICE. 1-800-222-7820
Apr 24, 2010 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
