Question about Mercury Boating
Marin shop has installled 5 starter solenoid and they all gone bad. 60 hp mercury 4 stroke. Why do they all go bad.
  • Mercury Master
  • 3,498 Answers
Try using on off a larger motor.(heavier duty).. or are they using aftermarket parts (sometimes inferior)
Posted on Jun 06, 2017
  • 20 Answers
SOURCE: issue with a 2004 40 hp 4 stroke mercury engine,
have you checked to see if there are any blockages
Posted on Jul 31, 2009
michael_skub
  • 7 Answers
SOURCE: smoking outboard
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Posted on Aug 23, 2009
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
  • 20 Answers
SOURCE: Subaru Impreza WRX 2003 won't start - starter will
check all wiring to starter, if all ok you have faulty bendix in starter. replace the starter and your problem will be corrected
Posted on Nov 26, 2009
  • 212 Answers
SOURCE: Starter Gone Bad -OR- Solenoid Gone Bad?
I would say it's the solenoid for sure!! Easy fix!!
Nice CAR!!!!
Posted on Feb 03, 2010
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Mercury mariner 2 stroke 60 hp starter motor removal problems
there are 2 clamps on the starter , top and bottom 2 bolts in each ! isolate the battery then disconnect the wires off the starter and remove the clamps and starter should come off !
Mar 09, 2015 | Boating
1987 Mercury 75 hp 2 stroke outboard motor clicks when we try to start it
Do you mean it clicks and starter not turning ? if yes then the starter solinoid wires are loose or it needs replacing ! more info needed !
Aug 16, 2014 | Clymer Mercury/mariner 75-275 Hp...
Ihave a vanguard 20 hp v twin on my snapper mower you turn the key and get like a kluk sounds like its coming from starter
Does it do it every time? First try and turn your engine by hand counter clockwise and try to start..sometimes the engine stops on a compression stroke and Is Under too much pressure for the initial start,..happened to my cub cadet laast week...,,if it turns and still gets a click...test or charge your battery..if it is ok you either have a bad solenoid or starter...first find the solenoid and croosing the two big post..it should spin the engine..if it spins it is your solenoid if not the starter is bad...not a hard job for either...both can be purchased at your local mower place...giid luck
Oct 24, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Nice CAR!!!!
Feb 03, 2010 | Mercury Cougar Cars & Trucks
Boating Logo
129 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Joseph Hoffmann
Are you a Mercury Boating Expert? Answer questions, earn points and help others
