Question about Sanyo Refrigerators
I have a sanyo hotwater dispenser it has a handpump on top that you manually push down to dispense water. When its pushed down it doesn't produce any water ?
PABLOCSA
  • 1124 Answers
SOURCE: Ice and water dispensing problem; compressor shuts off when paddle pressed but dispensing is sporadic
The ice remains stuck between the dispenser and the top of feeding ice. This respond to a broke rubber on the last section where the ice must be delivered. Replace the rubber will fixed the problem. It is a common problem on this kind of devices. To remove the ice simply move the stuck ice from the bottom oro yu can try putting some warm water from the top. Before to do nothing, unplugg your refrigerator first.
Posted on Oct 11, 2008
ricardok45
  • 135 Answers
SOURCE: Water dispenser not working in my Maytag Model #MFD2561 HES
Hi. Do an Internet search for Maytag recalls. Your fridg. may be on their list. If this solution has assisted you, please rate it. ricardok45.
Posted on Mar 14, 2009
SOURCE: ice dispenser not dispensing ice or water
The tube that supplies water to the tray of the ice maker,may have frozen solid. unclog u should be good
Posted on Jul 20, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Posted on Mar 11, 2010
Machine not taking powder
From your comment the water feed into the wash powder section of the dispenser tray is not working properly. Follow these instructions for first removing the dispenser and thoroughly cleaning and then clean all of the jets where the water is supposed to enter. Afterwards replace the dispenser;-0)
Try the following- in the second and third cases whilst looking from underneath!
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit).You may have to push the bottom of the dispenser upwards.
  • lift upwards on the tray as it is coming out to clear the lip underneath. Again you may have to push the bottom of the dispenser upwards.
Pull out the dispenser drawer far enough to be able to just see the trays, select each part of the cycle in turn (briefly to save time) and check that water is entering the trays. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | AEG Lavamat 72640 Front Load Washer
My side by side will not dispense ice, crushed or cubes. I hear it grinding, think it's impacted - maybe from clumped ice in the bucket. Is it better to use a hairdryer or run some hot water thru it?
Neither! Depending on the brand, open the receptacle for the ice cubes (usually on the top portion inside of your freezer, there's a small gate where you can grab ice withoutgoing through the dispenser).
Is there a wire bar that looks stuck upright? if so, then push it down and it will start producing and dispensing again.
Aug 03, 2011 | Refrigerators
The water backs ups from the dispenser tray and leaks out to the floor once the machine starts to add water. LG front load model WM2487H*M. It looks as if something may be clogged in the path from the...
Remove bottom phillips head screws from plastic clip on the back of the washer's top cover. Standing in front of machine, use the palms of your hands to sharply push back on the washer's top, pushing top back about 2 inches. Lift off top.
I've had to remove the dog food that a mouse put there after the dispenser drawer was left open.
Also, remove dispenser drawer by pushing tab down at back of drawer while pulling out drawer. I've had to clean out a thick layer of fabric softener from there already on another machine also.
Feb 26, 2011 | LG WM2487HA Washer
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Dispenser drawer and tub
softner dispenser has pushed down into the dasher. How to take off top of dasher to replace the small softner dispenser cup that was pushed down.
Apr 13, 2009 | Washing Machines
I have a Kenmore top loading washing machine that is 7-8 years old. (model # 110.92575110). It has a fabric softener dispenser that sits on top the agitator. It has stopped dispensing properly. Most of the...
pull the dispenser of turn it up side down now move green clip around dispenser down..take a little screw driver and remove all that wax build up...turn dispeser right side up and let hot water hot as possiable..now you should be find...if not add a little bleach with the hot water rinse out..if your getting fabric softner around tub ring ,,its to thick,,instead of dripping down its flying up...fill dispenser to top with water than add fabricsoftner ..it will even it self ,,water first...
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
Oct 11, 2008 | LG WM-2277HW Front Load Washer
Getting facelate off ???
use a butter/table knife (not sharp) and slip it under the plate at the bottom. pry the bottom off while pushing down on the top and it should pop off. once the bottom is off, push down on the top while pulling and twisting the loose bottom and the plate should come off. you then have access to the parts for the ice/water dispenser.
Jul 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
22 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
