Looks like brown rust coming from under washer washer about 2 years oldwhrilpool cabrio
  • 2,540 Answers
Sounds like a small leak. I would tip it up and see if you can see where the water is coming from. Could even be a bad rust spot.
Posted on Apr 20, 2017
The porcelin in the bottom of the bowl looks brown and like the porcelain has come off of my toto toilet
Toto toilets usually have a very good porcelain finish. I would first try a toilet bowl cleaner or a rust remover such as CLR or Lime Away. DO NOT ! MIX ANY OF THESE CHEMICALS UNDER ANY CIRCUMSTANCES! Try one making sure to give it time to work then thouroughly flush the toilet before trying another. The brown stain may be rust or water scale. If the porcelain is actually gone replacing the toilet is probably the only fix. Hope this helps.
Bob
Jun 27, 2014 | Toto Home
Is a small amount of brown moisture coming out of A/C w/cold air & slightly squeaking fan upon yearly startup on kenmore model 253.70101 acceptable : should i run it longer than 1 minute.
Brown is rust.
Painted metal outside for 2 yrs eventually rusts (ergo: brown drips) The fan is exposed to heat/cold/wet and the sintered bronze bushings may have lost their lubrication and/or the shaft is corroded, causing squeaks. Take the case off and try to lube the shaft bearings with oil, not WD40.
May 13, 2014 | Heating & Cooling
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Dark brown stains
Try running a cycle on hot with 1/2 cup dishwasher detergent (powdered) in it. Stop it before it pumps it out and restart again, Do this a few times to get a long scrub action. I don't think its oil as a front load machine doesn't have a transmission. If you think this is a rust stain use a rust remover type product instead of dishwasher detergent.
Jun 07, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
