Question about Sewing Machines
Bobbin thread not catching on straight stitch, 880 machine
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
  • 749 Answers
SOURCE: won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
SOURCE: Not catching stitches / bobbin correctly
Your timing has been messed up by breaking the needle.  When the needle hit the bobbin race, it shoved the needle bar up and now the needle is not in the correct position to catch the bobbin thread when the race rotates.  The needle has a little dip in the back, called the scarf.  When you take the neddle plate off and watch it move, you should see the little hook pass through the scarf.  That's how it makes the locking stitch and picks up the bobbin thread.  Unfortunately, you will need to take this in to a dealer or service place to have them adjust the needle bar height.  It's not a complicated task so see if they can check it while you wait.  It may be more difficult to fix, like retiming the machine.  But it doesn't sound like you've done any major damage to the mechanism.
Posted on Feb 08, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
Machine zig-zags but why does it leave a straight seam?
not catching the bobbin thread every time .
Nov 30, 2015 | Sewing Machines
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
Why needle is not catching the bobbin thread
All problems like this are caused by incorrect threading of the cotton thread. Even if you have done it before, thread the cotton using the instructions in the manual.
Also make sure the bottom bobbin and its housing are correctly inserted.
Aug 15, 2015 | Singer 3321 Talent Sewing Machine
How do I set a straight stitch? What is causing the top thread to break?
You do not say which machine you have. As for a straight stitch, make sure the needle is central and not in zig zag mode.
The thread can break for several reasons, such as. Incorrect tension.
:Wrong thread for the material.
: Thread in bobbin different from the top thread.
:Old thread.
: Not threaded correctly.
: Needle not inserted correctly, or incorrect needle.or the thread could be wound around the spool holder pin,
Try removing the spool and turn it around.
Hope this helps.
Mar 02, 2015 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Bobbin shuttle
1. Clean shuttle with your sewing machine brush to remove old broken threads, lint, and sweep out the feed dogs carefully. 2. Rethread making sure you have the handwheel turned toward you, all the way up. 3. Lift presser foot up BEFORE you put thread front to back in eye needle. 4. Set machine on straight stitch sewing. Attach straight stitch foot if necessary. 5. Make sure 5-6 inches of thread are pulled toward you from threaded needle. 6. Pull up bobbin thread. 7. Pull 5-6 inches of bobbin thread and put it, along with needle thread under presser foot. 8. Put fabric scrap under presser presser foot and LOWER it now. Make sure, too, that the needle is correct size for fabric you're sewing. 9. Do a test. You may need to set tension at 4, stitch length at about 4 and width at 6. Just test it and adjust tension in very, very short turns. Another tip: Put one drop of good quality sewing machine oil on the hook, lower left-hand side. Make sure when you thread bobbin in the bobbin case to hold bobbin between thumb and forefinger and pull out about 4 inches of thread after you make sure thread unwinds top left (if you are right-handed!). Guide the thread into the slot in edge of bobbin case (screw sits on top of this "edge". Pull thread under tension spring and then into the delivery eye. Never panic, my friend! Try this and see if this helps. You should probably insert new needle too--just in case "old" one bent. Jimmy
Mar 31, 2012 | Brother LS-2125 Mechanical Sewing Machine
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I had my machine in the closet for 5 years and now need to sew a hem on my cotton pants. What should the settings be set at? Right now it is at a 4 and the stitch length is a 2 1/2. The thread is too...
If your machine has been stored for 5 years, you should give it a good clean and oil according to the manual before you do anything else. Then put in a new needle and wind a fresh bobbin, checking that the bobbin has been wound smoothly as a badly wound bobbin can cause poor tension and stitching from the bottom thread.
You want the thread to go from the spool through a tension disc or eyelet to the bobbin and keep some gentle tension onto the thread spool using your scissors handle or similar so that the thread winds off it smoothly and the spool doesn't bounce around. Also give the thread a nudge with your finger tip as it winds onto the bobbin so it fills evenly, top, middle and bottom, not all in the middle.
Are you wanting a straight stitch to sew around the hemline? If so, your stitch length is right, but stitch width should be zero. You don't say what knob is set to 4, if its your top tension then that should be close, usually between 4 and 6 if dial goes from zero to 10.
Which thread is too tight? top or bottom. Firstly check the threading path to ensure that the top thread isn't catching on anything, is through the take up lever properly and coming from the thread spool without catching there. Some thread spools have a little knick in the top where you can catch the thread to store it, but you dont' want the thread to catch here when seaming, so turn it around the other way on the spool so it can't.
Try test stitching a medium zig zag stitch on scrap fabric, and you'll be able to see if the bottom thread is pulling in or the top one, then adjust the tension dial a little to lessen this.
Hope these pointers help, if you can't get a good neat stitch after trying these things, then consider taking it for a clean and service, the technician can get inside and clean the machine thoroughly and also check for any other issues that might be there.
Apr 30, 2011 | Singer 57815 Mechanical Sewing Machine
I tried servicing the bobbin area of my Singer 7442. I followed the instructions in the manual carefully. The straight stitch is working but all other stitches are not catching in the bobbin.
Couple of things to check is the needle new? if not change it,
Pull the bobbin thread out and bobbin case, then put the machine on a zig zag stitch, turn the hand wheel slowly and see if the hook (pointy thing that catches the thread) is just above the eye on the needle (when the swing is all the way to right) if it is not then you need to take your machine in for service.
Good luck and please rate my answer.
Mar 12, 2011 | Singer 7442 Mechanical Sewing Machine
The bobbin stitch is not as straight and tight as the top stitch. I'm using the right needle for the denim a 110-18.  I have the tension set at 9 and I have played with it =all the way down to 0....
Try adjusting the bobbin tension. My Pfaff (with a front load bobbin) has a tension adjustment on the bobbin housing. When you take the housing out, make sure there is no lint or stray thread caught anywhere in the bobbin casing, load the thread. Then dangle the bobbin housing from the thread end. A gentle pull (more like a ****) on the thread should allow the bobbin casing to slide down 1/2 inch or less. If the casing falls too far, increase the tension on the bobbin thread. Good luck.
Dec 29, 2009 | PfaFF Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
