Question about Sewing Machines
Top stich is normal, bottom stitch is loose - Sewing Machines
  • Sewing Machines Master
  • 11,474 Answers
Tighten up the top tension so it will pull the bobbin thread up. The top and bobbin threads should meet in the middle of the fabric.
Posted on Apr 20, 2017
my top thread is pulling thru to the underside..looks like little birds feet tracks on the back of the
Posted on Aug 09, 2008
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really .....actually .....need adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do is,
and eventually, you do get a "feel" for the correct tension and then it happens quite a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Posted on Sep 02, 2009
  • 255 Answers
SOURCE: loose stich on bottom of fabric
Hi. The problem is that your upper tension is too loose. It needs to be tighter in order to pull the bobbin thread up.
Posted on Apr 17, 2010
Testimonial: "This was only helpful in that is did not say HOW to fix the upper tention, being a nofice I don't know that, please help. Thanks Louis"
  • 109 Answers
SOURCE: i have a brother vx-1125 and the top stich is fine
If the bottom stitching is a mess it usually means that the TOP thread is not threaded correctly. What happens most of the time is that the thread is not snug in the tension discs. First re-thread your machine with the presser foot UP and when you get to the tension discs (sticking up at the back of the machine) hold your thread like you're flossing and go back and forth in the disc to make sure you have tension on it. You should hear a little click when it's in there. (Test it...floss it on and pull it off so you can hear the click.) If the thread isn't between these discs your bobbin thread will be loopy. Finish threading the machine and you should have no problem now. Also, make sure your upper tension is set at 4 and your stitch LENGTH (on the right front) should be 2.5 or 3 for a normal stitch. Hope this helps. Let me know! Thanks for using FixYa
Posted on Sep 10, 2010
  • 415 Answers
SOURCE: my top stich is tight,but bottom is loose of my
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Posted on Mar 23, 2011
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
May 19, 2016 | Sewing Machines
Singer Sewmate, the zig zag stitch is perfect on the bottom of the fabric, but lopsided on the top, how do I fix this?
This could be a combination of two things, to much down pressure on the spring loaded foot on top or the fabric distorting it, the other is a top stich tension issue adjust tension in and out to see if this improves the stich.
good luck
Feb 25, 2015 | Singer Sewing Machines
My stiches are loose on the bottom of my banner - is it the bobbin or a tension issue?
If the threads on the back are loopy, you need to tighten the top tension. If you have a spare piece you may want to run some of the plastic through the machine until you get the tension correct. If the top tension is too loose, the stitching will just pull out.
Jul 16, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Top stich perfict but bottom stich too loose on vivo singer machine 1004
Your bobbin tension needs adjusting, and although it is not hard to do and doesn't require that you take the machine apart, you MUST do it systematically. If you don't, you'll make things worse.
First, download the user's manual from the Singer site if you don't have one. On page 20, you'll see a discussion regarding tensions, and what improper tension looks like. Tension is a balance between the top and bobbin.
Then, using scrap fabric, set your top tension on Auto and make sure your needle is all the way up in the clamp. Run a line of straight stitches, and next to it, run a line of zigzag stitches, maybe four inches, and examine it. The illustration on that page will show you what your straight stitches SHOULD look like. If your zigzag stitches show one side that looks like "chicken tracks" but the other side looks like it should, the chicken tracks side is too tight. In your case, if the bobbin is too loose, the top will look like chicken tracks. It helps a lot to use two different thread colors, as well as a third for the fabric.
To adjust the bobbin tension, you will need a tiny straight blade screwdriver. If you have an indication that the bobbin side stitches are too loose, take the bobbin case out of the machine and locate two screws on the side. One is a Phillips--don't touch it. The one on the left of the Phillips is a straight-slot screw--that's the one you want. The saying is "lefty loosey, righty tighty." If your test indicates the bobbin tension is indeed too loose (which can happen over time), you need to tighten it by turning the screw 1/4 (ONLY) turn to the right (righty-tighty). Test again. You should see at least some improvement to indicate you're on the right track, and repeat--turning ONLY 1/4 turn--until your top and bottom tension are balanced. Don't forget to also test with a zigzag; I have adjusted bobbin tensions in the past that looked OK on the straight stitch, but the zigzag indicated I wasn't quite there yet.
Jun 25, 2014 | Singer 2638 Mechanical Sewing Machine
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
here is a free manual
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
My top stich is tight,but bottom is loose of my singer sewing machine.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Top stitche is to tight and bottom stitche is to loose
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
May 01, 2010 | Brother CS6000i Computerized Sewing...
The top stiches are overlaying and the bottom stitch is loose
Remove the thread from the machine.
Raise the presser foot.
Turn the handwheel until the take-up lever is at it's highest position.
Set the upper tension to 5.
Re-thread the machine.
Oct 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
