Water proofing mode on and wont shift wt 2780
My machine stopped and went into waterproof mode and it still had all the water in it i waited and waited and in the end had to open filter and drain all the water out and when the service man came he blamed me for the fault saying the floor was wet .couldnt get through to him that it was in waterproof mode before i emptied the machine.he was very cocky and dismissive and talked over me.is this an ongoing fault?
  • 5 Answers
SOURCE: DI 67 S fault
Try to tilt your dishwasher forwards. Be aware that water will leak out of the front. Once this is clear it should work. I paid an engineer to come and tell me this. If your machine is not completely level it causes it to over fill and after a time will not work. Good Luck
Posted on Jan 15, 2008
  • 156 Answers
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Posted on Feb 25, 2008
johnychel
  • 796 Answers
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
SOURCE: W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
Why is water not heating
Most washers require both hot and cold supply
Jan 06, 2017 | Miele Washing Machines
When Apple will release water-proof iPhones?
Apple has no current plans to release a waterproof IPhone. There are however several waterproof cases available that you can use in the meantime.
The following link describes 11 of the most popular waterproof cases.
http://www.digitaltrends.com/mobile/best-waterproof-iphone-6-cases/
Mar 23, 2015 | Apple iPhone Cell Phones
How do I get at the Motor on a WT 2780 Washing machine?
The most important thing you miss, is you should first diagnose what is defect. When 100% certain there is no cause for the defect other and died because of the usage and it is replaceable, you first should buy the spare part and then start the replacement. Without a manual I would not even start opening it. And when the motor costs more then half a new washing machine I would not even order one or replace one.
Please be careful when opening the machine. One mistake can cost your fingers or it even can cost a life.
Feb 09, 2015 | Miele WT 2780 Front Load Washer
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Problem
Could you please describe the problem you are having a little better?
Oct 20, 2012 | Miele WT 2780 Front Load Washer
How do i wash my Burton gloves , without losing the qualities like waterproofness?
The waterproof membrane material in your gloves is actually glued (welded) to the inside of the fabric and so is well protected. What you also have is a DWR coating that stops water getting into the outer layer of fabric that protects the waterproof membrane. All you have to do is visit your local outdoors store and ask for a good waterproof fabric friendly cleaner and a re-proofing product for the DWR coating.
Apr 25, 2010 | Burton Approach Snowboard Mitts La Gray
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
Dropped my Olympus Stylus 1050 SW... now it wont turn on!
make sure the battery is charged and if it is and u r still having this problem try pluging it in a pc to see if your camera still works if it is maybe the lenz is messed up and if thats the case i cant help u with that
Sep 21, 2009 | Olympus Stylus / mju 1050 SW Digital...
Not working.
Seems like olympus got us in!. I have the same problem. I called Service & Guarantee center in Mexico. They told me to send it to them: They will evaluate if the guarantee covers the damage. They also said the procedure about waterproof checking. If there is a sand grain or a hair in the rubber-type seals, and it licked thru those, the guarantee is voided and i have to pay for repair. Good God, the camera is water proof, shock proof but hair and sand proof! hope to find an answear soon. I am about to throw it into the basket if the brand will come with an excuse like that.
Jun 09, 2008 | Olympus Stylus 790SW Digital Camera
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
