Question about Cell Phones
How do I choose a network for setting up my iphone?
How do I activate 6s iphone? I have made the transfer from cloud, just need to activate
You must contact your cell phones service provider, we are not that company.
Nov 16, 2016 | Cell Phones
How to Transfer Photos from iPhone to iPhone 6
For the people who just upgraded from a relatively old iPhone to the new iPhone 6, they may like to transfer some of the wonderful photos from the old device to the new one. Every iPhone user knows that we can transfer photos from iPhone to iPhone via Photo Stream. However, it requires two device are log into the same Apple ID and iCloud account, and it only sync when the 3G/4G/Wi-fi network is available. What if the network is not stable and you want to selectively transfer photos from iPhone to iPhone 6? So, in this tip, I will talk about how to transfer pictures from iPhone to iPhone 6 via Photo Stream and an iPhone content manager - AnyTrans.
How to Transfer Photos from iPhone to iPhone 6 via Photo Stream
Step 1. Go to Settings from your iPhone > Scroll down to Photos & Camera >Toggle "My Photo Stream" to ON position.
Step 2. Do the same with your iPad. Make sure the same iCloud account is connected to both devices by going to Settings > iCloud.
How to Transfer Photos from iPhone to iPhone 6 via AnyTrans
Step 1. Open up AnyTrans, and connect both your iPhone 6 and iPad to computer. Enter the manage page of your iPhone.
Step 2. Select "Photos" > Choose photos you want to transfer from Camera Roll/Photo Stream/Photos Library/Photo Share/Album/Panoramas.
Step 3. Choose the photos you want to transfer, and click the To Device button to transfer pictures from iPhone to iPad.
Resource from
How to Transfer Photos from iPhone to iPhone 6 Plus Directly
on Dec 23, 2014 | Apple iPhone 6
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
My messages on my phone aren't in order
  • Set your iPhone to official time If you are in the United States, go to and check the current, official time, then set your iPhone to that time in "Settings" (as close to the minute change as you can).
  • Use network time "Make sure iPhone is setup to receive the network time. Choose General > Date & Time and turn Set Automatically to ON. (Note that in some locations, network time may not be available and in some cases, you may not see this option).However, this solution may not work in all cases.
  • Restart Some users have reported that powering off their iPhones (by holding down the sleep/wake button until the slider appears, turning the unit off, then back on) resolves this issue.
Aug 02, 2016 | Apple iPhone 6
I cant connect to wifi the wifi symbol is grey
Reboot your modem and/or router. Then select connection. Go into properties and choose forget this network. Afterwards choose wifi network. You should be able to connect now.
Jun 29, 2014 | Apple iPhone 4S
Internet setting of Tata docomo for iphone 5
for 3G settings: go to settings--cellular--cellular data network-- enter the APN name then go back and enable cellular data and enable 3g.
for WIFI: go to settings--WIF--enable WIFI-- then choose a network and connect to enter password if requested
Oct 23, 2013 | Apple iPhone 5
I can't connect my IPhone to my network
First verify the password you are trying to use is correct. You can only legally obtain this by asking for it or if you know it because you own it.
Second, sometimes ipod touch and iphone don't like changes. First go under General settings and Wi-Fi, then select the network, choose to delete the network. Exit back out and then go back in General, Wi-Fi and choose to connect it will then ask you for new password and if they match then you will be allowed to connect properly.
Jan 08, 2013 | NetGear PROSAFE Computers & Internet
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
IPhone issue.
be careful the next time you modify anything out of normal operating procedure. Try restarting your computer and running itunes again with restore, If that does not help, to get some money out of it put an ad out for BRICKED IPHONE 100$.
Aug 12, 2007 | Apple iPhone Smartphone
Cell Phones Logo
1,151 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
