DMR-EZ48V F03 code - Televison & Video
  • 6966 Answers
SOURCE: DMR-ES40V Error Code F03
If I may add to JoshOHoward's posting and with his indulgence.
The F03 (Fault 03) error indicates possible problem with your DVD's mechanism, specifically the either the spindle or the transverse servo drive. This is the motor and drive mechanism responsible for moving the carriage that contains the optical reader/laser eye forward and backwards.
What perhaps you can try:
1. do a soft reset. With no disc, press and hold the power button for more than 10 seconds. Alternately, you can unplug the unit for an hour or so.
2. Do a force initialize. With no disc inside, eject the tray, close the tray simultaneously pushing on the back skip, pause and play buttons
3. Do a full hard reset. With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds.
If the above does not prove to be corrective of your concern, pls post back since further diagnosis/repairs require opening the unit.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 13, 2008
SOURCE: DMR-EZ48V Clock no longer displayed on the front panel
Turn off power saving.
Posted on May 27, 2009
  • 50 Answers
SOURCE: Has any one a hack code for Panasonic DMR-EZ48V to
Posted on Jul 23, 2009
SOURCE: Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Posted on Oct 17, 2009
SD Tech
  • 14553 Answers
SOURCE: Panasonic DMR-EZ48V won't read disk
Either a dirty or a bad optical pickup in the DVD unit--one or the other.
Posted on May 26, 2012
Can't get into the setup on Panasonic dmr ez48v remote says rc2 I tried to switch to rc2 on the remote it does nothing
See if you can access the factory reset on the VCR, that should send everything back to normal.
Oct 23, 2016 | Panasonic DMR-EZ48V DVD Recorder
Manual for my ram dvd player dmr-ez48v
Panasonic has the owner's manual for the DMR-EZ48V on their product support page. Go to and click on the Owner's Manual tab (second from the left). The direct link to the manual is . (Note: this is the US version of the DMR-EZ48V.)
I hope this helps.
Oct 18, 2014 | Panasonic Dmr-e20 Dvd/ram/dvd-r Recorder /...
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code. - - free.htm - -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
What is remote code for panasonic dmr ez48v
This is the code-Panasonic 100, 101, 125, 130. You can also check this link for other relevant information-
Mar 21, 2010 | Televison & Video
Panasonic dmr-ez48v error f09 what is it?
If I have got the right machine than F09 is an electrical fault. If It is a K Deck model (you need to check) then it means: No serial clock linking IC2004, IC7005 and IC7701.
Nov 14, 2009 | Panasonic Televison & Video
Panasonic DMR EZ48V will not go into Functions
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
