F & P Elba Washing Machine squeaks on spin cycle ? (This Machine is in as new condition and has had very little use). Squeak appears to be of rubber. How can I lube or fix this ?
SOURCE: Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel. 6b657f1.jpg
Posted on Jan 11, 2008
  • 14 Answers
SOURCE: Squeak upon spinning
Hi, I wanted to comment on this because I have the Majestic MJ9200 Washing machine front load for the RV. I am having the exact same problem and I cannot use my machine at this time. This is NOT an unbalanced load problem. An unbalanced load will cause a loud banging noise because the drum is off balance. There is something wrong inside your machine. Mine never had this problem before either and an unbalanced load does not cause this horrible screech while on the spin cycle. My machine like yours made the noise only on certain spin speeds, high 1500 rpm spin the first time and when I adjusted the spin cycle just to see what happened it stopped making that horrible noise. I washed another load and it began that same screetch while spinning and it was then in all RPM ratios available on my model.
My husband took the top off the machine and could not see anything evident but when looking into the front of the machine we could tell that is seems the interior drum is much looser in the washing machine than in the dryer. There are two drums on the front load. A larger outer drum and a smaller inner drum. The inner drum is what is looser in our machine and the noise is a very loud screetch while spinning the water out of the clothes.
Is your machine under any kind of warranty? Mine is not and I am waiting to get it fixed.
Good luck on getting yours fixed and perhaps we can both help each other out on this one although we have different brands of machines...
Posted on Jan 14, 2008
jsrock516
  • 5911 Answers
SOURCE: Maytag Atlantis Washing Machine
The loud squeak at the end of the spin cycle is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking (causing movement of the washer) went the spin cycle stops. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself. NOTE: There should be a warning label explaining this
You can find all your parts and information at repairclinic.com. Just type in your model number in the search menu.
The parts required to make the repairs aren't very expensive, but the tool required to do it can be a bit pricey. If you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good about providing the necessary instructions with their parts, however.
In summary this job involves the following steps:
1. Removal of the front case to access the washer interior.
2. Removal of the drive belt and pulley from underneath the washer.
3. Removal of the drain hoses from the wash tub.
4. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
5. This is where the brake compression tool will be required to remove the brake rotor, stator and snubber ring.
Now, I am summarizing this job quite a bit. If this is something you wish to try to repair yourself, and you need more instructions, let me know. I hope this helps you.
Posted on Feb 09, 2008
JULIANFIX
  • 975 Answers
SOURCE: high pitch squeak when on spin cycle
looks like you need to replace the main DRIVE BELT , first open the panel to access inside the washer , give it a test wash and look at the bottom where the belt is , check if belt is tight , if you still hear the squeak try lubricate spray to the pulleys and avoid spaying the MAIN BELT . hope this info works
Posted on Apr 18, 2008
SOURCE: Washing machine squeak
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
Posted on Jan 13, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
During the spin cycle it has started to squeak? it sounds like rubber, maybe the seal or the fan belt?
If it squeaks or spins slower than when it was new, and/or you smell something like burning rubber, it is probably the belt. You can replace it yourself if you look up the make and model number on the internet. There are free sites that will walk you though the process. free.
Jun 19, 2011 | Neff Washing Machines
I have a Fisher & Paykel smart drive 9 excellence 7.5 washing machine and the is a squeak coming from the bottom of the tub?
Hi Craig,just read your posting.The squeak could be the bearings.Is the machine noisy on spin?Could you reply back and tell me what part of the cycle the squeak happens.Looking forward to your reply.
May 17, 2011 | Washing Machines
When the new machine which is only 3 days old is operating on a spin cycle there is a squeak noise during spin cycle no matter the spin speed.
Unlikely to be anything Major, Could be levelling check machine is level/secure on floor if still concerned phone company for advice....Good luck
Mar 07, 2011 | Washing Machines
Can not run spin cycle bang bang bang
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 04, 2009 | Washing Machines
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
Jan 11, 2008 | Star Speed Queen AWS53NW 26" Top-Load...
Jan 06, 2007 | Amana ALW895 Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
