Question about Janome Sewing Machines
I took the screw off the bobbin winder on the top of my janome memory craft 500 E. I cannot get it back on it just turns.... is there a video on how to put it back on
    Top Expert:
  • Janome Master
  • 40,500 Answers
Check YouTube for something similar
Posted on Apr 19, 2017
SOURCE: Sewing Machine CS-8060
I do have the very same problem! I took my bobbin case out and took a good look at it, turns out right below the plastic hook part, the plastic was cracked off (probably due to thread jamming). Turns out I need a new internal bobbin case, which range in price from $35-$50 from what I researched. I had no luck with local sewing centers on finding the part.
That may (or not) be your issue as well. Good luck, and I hope this your issue is simple fix. A little tune up after might be needed, HAPPY SEWING!! ~Kelly J~
Posted on Oct 14, 2008
  • 1116 Answers
SOURCE: I have a Janome Memory Craft 4800 Quilter's
Your sewing machine needs to be taken into an authorized dealer for service.
Posted on Apr 08, 2010
  • 10515 Answers
You need to replace the rubber ring.This rubber ring just snaps on and you can do it yourself, just click on the link below to order a new one from Sears.It is the most common problem with the bobbin winder, I have changed many over the years.You need to remove the screws as it would be under cover.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 18, 2010
  • 1564 Answers
SOURCE: Janome Memory Craft 8900 QCP. Upper tread jamming in the bobbin area and around. Needle jumps randomly on one side. Was sowing quite thick material with straight stitch and it was fine. Then I decided
Did it break the needle when you changed stitches? Or did it just go straight to jamming.
Posted on Nov 30, 2012
  • 53 Answers
SOURCE: Janome 5000Memory craft sewing machine bobbin repair manual needed
Please Look HERE
Posted on Mar 29, 2013
Bobbin winder
Access from top, and you can replace the unit with a new one....needs to be ordered through a Janome Dealer
Drop us a line if you have troubles
Contact Us at Bargain Box
Jan 05, 2014 | Janome Memory Craft 9000 Computerized...
I have a Janome memory craft 5700. when I turn it on the screen light up with an error of a picture of a bobbing with a piece of thread stretch from the top. No further activity. How can I solve this...
This is due to the bobbin winder being in the Right hand position read to wind,....but with no bobbin in it....just move bobbin winder to Left to disengage.
Bargain Box
Jan 18, 2011 | Janome Memory Craft 5700
My winding bobbin display will not go off screen. I wound a bobbin and when I moved the switch back to remove the bobbin, the display will not leave the screen. It will not go away even when I turn the...
The machine has a small micro switch under the lid of the machine that is either stuck or bent. Remove the top and look in the area of the bobbin winder and flip the winder to engage and disengage. You should see a swith that the bobbin winder pushes against. That should be the problem, if it is bent you may be able to straighten it out.
Oct 14, 2010 | Janome Memory Craft 4900QC Mechanical...
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
Jul 11, 2009 | Janome Memory Craft 9000 Computerized...
Bobbin is not filling. It barely turns.
This happened on my Janome had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
Nov 25, 2008 | Janome Memory Craft 9000 Computerized...
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
29 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
