Question about Kenmore Washing Machines
Kenmore Model number 796.4137 is leaking from the back left corner (when looking at the machine). How can this be fixed?
  • 770 Answers
SOURCE: kenmore 80 series leaking
the pump is most likely the cause if you have mach skills i can walk you thru it on how to open the unit and check it let me know
Posted on Jan 24, 2008
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
SOURCE: washing machine broken, kenmore model 110.92274100
I have the same problem as posted on mar 30, 08. seems like the clutch will not engage, the motor turns but the drum won't spin (wash. move). would you give us follow -up instructions for clutch & gear case on how to replace it.
Posted on Jul 27, 2008
  • 19396 Answers
SOURCE: Water leaking
I guess it was water from drain lines, or leak from water lines.
Posted on May 22, 2009
  • 4736 Answers
SOURCE: Water leaking out of frigidaire
First, have you drained the tank recently. If not, the warning light or auto shutoff failed and the tank may be overflowing. Worse case scenario is the that the tank is dirty and is not allowing the coils to cool and the dripping water you see is from the cooling coils. Since the tank is not removable, it's very difficult, at best to clean the tank.
If you drain the tank and before reinserting the drain plug, try to get about 1/2 teaspoon of bleach in the drain hole. followed by 2 cups of water. Of course you'll have to use a funnel of sort to do this. Reinstall the drain plug and move the unit around so the water and bleach will slosh around. Then run the unit until the bucket is near full again and drain it thoroughly. Look at the color of water draining out, for an indication that there is dirty water. That will be a good indication, that some cleaning of the tank has taken place.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 29, 2011
Elite he 3t front loader. Why does it leak water at beginning of rinse and spin cycle only?
Is it leaking from the tray top left corner? Mine was because it was not level. IT was level left to right but not front to back. The front was lower than the back. Raised both front feet, no more leaking.
Oct 22, 2015 | Kenmore Washing Machines
Leaking bottom left corner
possibly but no make no model we can not look for clues as to a fix
Apr 27, 2015 | Washing Machines
Kenmore instruction manuals
The Sears site has many of the manuals in PDF. Know your model number (open the door, look upper left corner on machine) and it will go quicker.
Jul 21, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I have a gasket around the top of the tub that is leaking. I have had a repair man twice and he finally told me he can't fix it because he cant find the model number. Where can I look for it? It's...
Typically the model number is in one of 3 places
inside the lid
on the back of the control panel
on the lower left front corner of the cabinet on the left side wall of the cabinet
Aug 30, 2011 | GE WBSR3140DW Top Load Washer
Why would my HE washer intermittenly leak a little water from the left front corner?
The TUB RING is your culprit they have come out with a redesigned part that fixes this concern.I could supply you with the part number but need the complete model number,and if this unit has an agitator or no agitator..
Sep 10, 2010 | Kenmore Oasis HE 27082 Top Load Washer
KENMORE WASHER 110.267.91690 pump leaks. Can I
If you are mechanically inclined and have a few basic tools, Yes you can. I have instructions for you and this link will take you to Sears website for drawings and parts direct.
Disconnect the power cord. Turn off the water. There are two clips, one at each front corner, holding the control panel in place. 1. The best tool to use to unhook these clips is a putty knife. From the front push the putty knife between the machine top and the control panel at either outer corner of the control panel . You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring clip releases the control panel corner will lift easily. Repeat at the other corner. 2. Now, simply and carefully roll the control panel over the back. Do not force, some models have screws in the back top corner of the panel check this before rolling panel over the top. 3. Unplug the wire that connects the control panel to the top of the case. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the front of the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. The pump is the most forward part in the bottom of the case. There are two clips attaching the pump to the machine. Carefully release them with a flat blade screwdriver. There are two hoses attached to the pump and can be reused with the new pump. Be prepared to catch residual water left in the hoses from the last run. Unless you had a pump leak then they are probably empty. But best to be prepared. Allow 30 to 45 minutes for the first removal.
If the link does not work, an exploded view of your machine is available at under the parts direct tab enter your model number, found under the lid at the back of the tub opening. Copy and paste model number if needed.
If you have any questions, I am here at least onc a day. Good luck.
Jul 09, 2010 | Kenmore Washing Machines
Where can I find the model number on my kenmore elite washer?
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Leaks at bottom lefthand corner when filling
On that model it's easy to unscrew the front and take it off. You can then see the hoses etc to see where the water is coming from. I had to replace the drain hose on mine.
Aug 12, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 80 series leaking
Jan 24, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer-leaking
look where you posted this in the range secton repost in the washer section thanks
Dec 17, 2006 | Tappan TGF320 Gas Kitchen Range
Washing Machines Logo
43 people viewed this question
Sal De
 Brian Main
Brian Main
